Home » Eclipse Projects » Eclipse Platform » Add New Wizards to the File>New shortcut
Add New Wizards to the File>New shortcut [message #336234] Tue, 02 June 2009 10:24 Go to next message
Originally posted by: mickael.istria.openwide.fr
Hi all,
I am trying to have my New Wizards accessible as shortcut when clicking
on File > New. I already have the in the new Wizard dialog when clicking
"Other....", but I'd like to have them in the shortcut area just under
New (before clicking on Other).
How can I do that?
Thanks in advance
Mickael
Re: Add New Wizards to the File>New shortcut [message #336235 is a reply to message #336234] Tue, 02 June 2009 10:32 Go to previous messageGo to next message
That's done through the org.eclipse.ui.perspectiveExtensions short cut
(or o.e.ui.perspective if you are provding your own)
PW
Paul Webster
Re: Add New Wizards to the File>New shortcut [message #336242 is a reply to message #336235] Wed, 03 June 2009 04:22 Go to previous messageGo to next message
> PW
Hello Paul,
Thanks for your answer. Unfortunately I did not succeed to see the
wizard shortcut on specified perspective by adding a newWizardShortcut
to the perspectiveExtensions.
There is no problem to define the extension (perspective and wizard
exist and are found by the "Browse" menu), but it is not displayed in
shortcuts... I campared my extension with o.e.jdt.junit extension to
Java perspective and it is exactly the same thing, but JUnit works.
Do you have any idea of what could cause this issue?
Mickael
Re: Add New Wizards to the File>New shortcut [message #336243 is a reply to message #336242] Wed, 03 June 2009 05:19 Go to previous messageGo to next message
I think you should be extending o.e.u.newWizards.primaryWizard for that
- Prakash
http://blog.eclipse-tips.com
Re: Add New Wizards to the File>New shortcut [message #336244 is a reply to message #336243] Wed, 03 June 2009 05:45 Go to previous messageGo to next message
> - Prakash
Hi Prakash,
I aloready added them as primaryWizards (and it works, they are on top
of the wizard list when selecting "Others"), but this does not seem to
affect the shortcuts.
Mickael
Re: Add New Wizards to the File>New shortcut [message #336245 is a reply to message #336244] Wed, 03 June 2009 06:07 Go to previous messageGo to next message
Ignore my previous post. For shortcuts in the Menu, what Paul said
should work. Did you try resetting your perspective/open the target in a
new workspace?
- Prakash
Re: Add New Wizards to the File>New shortcut [message #336247 is a reply to message #336245] Wed, 03 June 2009 07:06 Go to previous message
> new workspace?
> - Prakash
Ok, that was it: restarting the perspective.
Thanks a lot to Paul and you!
Mickael
Previous Topic:get the active project
Next Topic:Starting help system webapp
Current Time: Mon Nov 03 07:19:25 EST 2025
Powered by FUDForum. Page generated in 0.12202 seconds
