| Re: Cannot set Key Binding for Compare with -> Local History [message #336229 is a reply to message #336226] |
Tue, 02 June 2009 01:36  |
> Remove the filter... so you can see uncategorized
> commands, and then search for "Local History"
> You'll have to look at the description of each one,
> to see which is the correct one.
Thanks Paul - that worked nicely.
The short-cut didn't work.. until I realised I cannot activate it from the
Editor: I can only activate it from an explorer view like Navigator. Also,
there are two views that compare with local history, one that displays
results in the History view, another that displays results in a pop-up. In
the Preferences > General > Keys view, there is nothing to separate them.
Oh well, I don't mind - I set a keyboard command for each one. :)
Rob
FUDForum. Page generated in 0.03968 seconds
