Home » Eclipse Projects » Eclipse Platform » No more Activator.getDefault().getBundle().getLocation() and Activator.getDefault().getStateLocation
No more Activator.getDefault().getBundle().getLocation() and Activator.getDefault().getStateLocation [message #336220] Fri, 29 May 2009 21:19 Go to next message
In eclipse 3.4.0, a plug-in's activator class has the getBundle() and
getStateLocation() methods. In 3.4.2, they are gone. :-(
Is there a substitution to this?
I am basically find way to access the artifacts (the files) that I have
in my plug-in when it's running.
Thanks.
Re: No more Activator.getDefault().getBundle().getLocation() and Activator.getDefault().getStateLoca [message #336221 is a reply to message #336220] Fri, 29 May 2009 23:49 Go to previous message
AL wrote:
> Thanks.
Not sure what you are seeing, but both methods should definitely be
there. I know that they are there in 3.5. They are defined in the
org.eclipse.core.runtime.Plugin class. Your Activator should subclass
Plugin.
Previous Topic:Wizard and getNextPage
Next Topic:space value in plugin.xml
Current Time: Sat Nov 15 08:25:57 EST 2025
Powered by FUDForum. Page generated in 0.03377 seconds
