Home » Eclipse Projects » Eclipse Platform » `/etc/startup.mk' not found
`/etc/startup.mk' not found [message #336143] Tue, 26 May 2009 10:27 Go to next message
I am trying to run ganymede on a Windows XP pro based pc for the first
time. I am trying to build the Hello World example. When I select Clean
and then it attempts to rebuild, I get this error. I have searched the
web pretty thoroughly, but can not find out what I am doing wrong.
**** Build of configuration Default for project HelloWorldRAP ****
make all make: Error -- Configuration file `/etc/startup.mk' not found
I even tried some stuff from a command prompt window:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
p:\>make --version
Defined macro MAKECMD=make
make: Unknown option --
Usage: make [-eEiMnpqrstuvVx] [-k|-S] [-c dir] [-D macro=value] [-f file]
[macro
=value ...] [target ...]
Note: I do also have MKS integrity installed for another project. But, I
also have another co-worker that does not and they are having this same
problem.
Re: `/etc/startup.mk' not found [message #336148 is a reply to message #336143] Tue, 26 May 2009 12:41 Go to previous message
> p:\>make --version
> file] [macro
> I also have another co-worker that does not and they are having this
> same problem.
Re-routed to CDT
Paul Webster
Previous Topic:Unresolved Inclusion
Next Topic:org.eclipse.debug.ui.consoleLineTrackers
Current Time: Thu Nov 06 09:47:09 EST 2025
Powered by FUDForum. Page generated in 0.02897 seconds
