Home » Eclipse Projects » Eclipse Platform » Distributing prefs
Distributing prefs [message #336135] Mon, 25 May 2009 15:22 Go to next message
Originally posted by: jonatan.ogdo.frich.dk
Sometimes it is useful to be able to propatage / push preference
out to team members. I have found some old post with this topic
but they is more about writing a custom solution. But is this possible
somehow within the 3.5 / e4 timeframe
(Not sure if this question relates to the platform or P2 so I cross-post)
BR
J
Re: Distributing prefs [message #336136 is a reply to message #336135] Mon, 25 May 2009 15:33 Go to previous messageGo to next message
> BR
> J
If the preferences are specific to a project then you can set project
specific preferences. These are saved in a .settings folder in the root
of the project. You can add the .settings folder to your SCM. Then
other users will automatically pick them up when checking out the project.
Re: Distributing prefs [message #336141 is a reply to message #336135] Tue, 26 May 2009 10:06 Go to previous messageGo to next message
Have you considered using something like Yoxos to build your own
distribution for your team members?
http://yoxos.eclipsesource.com/
http://eclipsesource.com/en/yoxos/
Yoxos has the ability to do workspace provisioning for your team members
once you setup a profile.
~ Chris
Re: Distributing prefs [message #336190 is a reply to message #336136] Thu, 28 May 2009 10:44 Go to previous message
Originally posted by: jacek.pospychala.pl.ibm.com
David Wegener pisze:
or if you want to share Workspace preferences, use Preferences Export
wizard to save all your preferences to file and then Import wizard to
load them back.
Rational Elite Support for Eclipse
Previous Topic:Listener when unload/load resource
Next Topic:StatusBar within a View??
Current Time: Sat Aug 30 06:19:17 EDT 2025
Powered by FUDForum. Page generated in 0.03612 seconds
