Re: Making View Visible After Mouse Click [message #336113] |
Thu, 21 May 2009 16:04 |
Note: the proper newsgroup for questions about views is
eclipse.platform, which I've copied to this response.
Take a look at org.eclipse.ui.IWorkbenchPage.showView(String viewID).
One way to get a reference to the "current" workbench page is via
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage(),
but make sure to read and understand the documentation of each of those
methods and interfaces so that you call it under the proper circumstances.
Hope this helps,
Eric
Humfred Dupont wrote:
> Hello Guys,
> I have a view and i want it to be visible whenever a user clicks on
> a button. The view class extends the ViewPart class. I checked through
> the available methods but there is no method that i can use. The user
> always has to go through the window-->show view -->other before he can
> access the view but i want the view to be visible whenever he clicks on
> a button.
> In the button event handler i instantiated the view class but it is not
> working. This is a snippet of wat i did:
> //additional code here
> public void widgetSelected(SelectionEvent e) TreeView tr
> = new TreeView();
> tr.createPartControl(parent.getShell());
> Is there a method or a way that i can let the view visible after mouse
> click?
> Thanks.
> Humfred.
FUDForum. Page generated in 0.05234 seconds
