| path in editor menus [message #336078] |
Tue, 19 May 2009 21:24  |
In Extension Points Reference Menus for Editor Munus, Toolbars and
Actions, I find the following description for munu:
<!ELEMENT menu (separator* , groupMarker*)>
<!ATTLIST menu
id CDATA #REQUIRED
label CDATA #REQUIRED
path CDATA #IMPLIED>
This element is used to defined a new menu.
id - a unique identifier that can be used to reference this menu.
label - a translatable name used by the Workbench for this new menu. The
name should include mnemonic information.
path - the location of the new menu starting from the root of the menu.
Each token in the path must refer to an existing menu, except the last
token which should represent a named group in the last menu in the path.
If omitted, the new menu will be added to the additions named group of the
menu.
Can some explain path in details based on the following example:
<menu
label="%_UI_ValidationMenu_label"
path="org.eclipse.example.loyaltyMenuID/additions"
id="org.eclipse.emf.validationMenuID">
<separator name="additions"/>
</menu>
So org.eclipse.example.loyaltyMenuId is an existing menu, where can I find
it? Thanks.
Will
FUDForum. Page generated in 0.05862 seconds
