Home » Eclipse Projects » Eclipse Platform » [CommonNavigator] setting up initial input accross many providers
[CommonNavigator] setting up initial input accross many providers [message #336074] Tue, 19 May 2009 14:11 Go to next message
Originally posted by: aczerwonka.3esi.com
Not sure that I'm "getting it".
I'm wanting to setup the common navigator for central navigation of our RCP
product. I have threee separate clients (internal development teams) for
this central component. I've gone through the contentBinding, actions...
all that jazz. All good. Basically each group can define their own content
extensions. Perfect. Where I get confused in how each group can set their
own initial input into their own models. What I'd like to see if that each
group would contribute one root folder that they could their content.
Something like the following:
+--Group 1 Root
-- Group 1 Content
+--Group 2 Root
-- Group 2 Content
+--Group 3 Root
-- Group 3 Content
I don't want Group 1, 2 ro 3 knowing anything about eachother. How can each
group set their initial content? Is there an example out there? Right now
I've extended CommonNavigator with my own and overridden getInitialInput(),
but that binds everyone together. Is there an example out there somewhere I
can steal from?
andy
Re: [CommonNavigator] setting up initial input accross many providers [message #336075 is a reply to message #336074] Tue, 19 May 2009 14:14 Go to previous messageGo to next message
BTW, I'm just wanting support for the first use case as described here:
http://scribbledideas.blogspot.com/2006/06/what-does-common- navigator-framework.html
Saying that, in this case, there is only one input, the file system.
"Andy Czerwonka" <aczerwonka@3esi.com> wrote in message
news:guusp6$fpu$1@build.eclipse.org...
> RCP product. I have threee separate clients (internal development teams)
> for this central component. I've gone through the contentBinding,
> actions... all that jazz. All good. Basically each group can define
> their own content extensions. Perfect. Where I get confused in how each
> group can set their own initial input into their own models. What I'd
> like to see if that each group would contribute one root folder that they
> could their content. Something like the following:
> +--Group 1 Root
> -- Group 1 Content
> +--Group 2 Root
> -- Group 2 Content
> +--Group 3 Root
> -- Group 3 Content
> each group set their initial content? Is there an example out there?
> Right now I've extended CommonNavigator with my own and overridden
> getInitialInput(), but that binds everyone together. Is there an example
> out there somewhere I can steal from?
> andy
Re: [CommonNavigator] setting up initial input accross many providers [message #336076 is a reply to message #336074] Tue, 19 May 2009 16:13 Go to previous messageGo to next message
I found this two-year-old comment basically describing my issue:
http://rcpquickstart.com/2007/04/25/common-navigator-tutoria l-1-hello-world/#comment-7
Is this use case still not resolved?
> +--Group 1 Root
> -- Group 1 Content
> +--Group 2 Root
> -- Group 2 Content
> +--Group 3 Root
> -- Group 3 Content
> andy
Re: [CommonNavigator] setting up initial input accross many providers [message #336134 is a reply to message #336076] Mon, 25 May 2009 13:26 Go to previous message
I think you just need to define your own toplevel object that each
"root" adds to. You can either define a root object that everyone
derives from (if all your roots are similar in some way) and some type
of registration/add-a-root mechanism or use something else, such as an
eclipse extension, to define that root object. Your RCP would then just
access that extension to grab all the roots defined and add them to the
list that the toplevel object maintains.
>> +--Group 1 Root
>> -- Group 1 Content
>> +--Group 2 Root
>> -- Group 2 Content
>> +--Group 3 Root
>> -- Group 3 Content
>> andy
Previous Topic:Strange behaviour of an open shell (needs a mouse click twice before noticing any event on the shell
Next Topic:ERROR: ‘Not implmented in this version’ for xml transfom.-Please help
Current Time: Wed Nov 05 22:11:53 EST 2025
Powered by FUDForum. Page generated in 0.03347 seconds
