Home » Eclipse Projects » Mylyn » Synchronizing a task in the editor
Synchronizing a task in the editor [message #34114] Mon, 22 October 2007 19:07 Go to next message
Originally posted by: baksoy.collab.net
I am trying to synchronize a task in the Task Editor. As far as I
understand, the new (downloaded) RepositoryTaskData is used only if the
value of DateModified attribute is changed. However, there might be some
changes performed on the task that don't affect the DateModified
attribute. Therefore, synchronization in the editor does not reflect the
changes in the repository. Is there a way to make
RepositorySynchronizationManager#checkHasIncoming(...) method to make
its decision based on an attribute other than/in addition to
DateModified attribute.
thanks,
Re: Synchronizing a task in the editor [message #35057 is a reply to message #34114] Fri, 02 November 2007 22:13 Go to previous message
Originally posted by: beatmik.acm.org
Hi Baybora,
Could you please send this question to the mylyn-integrators list?
http://www.eclipse.org/mylyn/community/
Mik
Baybora Aksoy wrote:
> thanks,
Re: Synchronizing a task in the editor [message #584241 is a reply to message #34114] Fri, 02 November 2007 22:13 Go to previous message
Hi Baybora,
Mik
> thanks,
Previous Topic:Mylyn and Palm connector?
Next Topic:Aren't my editors supposed to auto-close?
Current Time: Fri Nov 07 08:30:29 EST 2025
Powered by FUDForum. Page generated in 0.07346 seconds
