Home » Eclipse Projects » Eclipse Platform » binding eclipse ganymede with jboss over https
binding eclipse ganymede with jboss over https [message #336048] Fri, 15 May 2009 02:32
Originally posted by: dave.nospam.com
I've setup JBoss (4.2) to use certificates and run over https on port
8443 and I've tested I can bring up the JBoss console in Firefox using
my browser certificate.
I've tried to get Eclipse to deploy to the JBoss server and then startup
JBoss. The deploy works fine and the Eclipse console reports that JBoss
has started but Eclipse continues in 'starting..' state until it times
out. During this time the deployed application is accessible in Firefox.
In the Eclipse server configuration I've setup the address to be
127.0.0.1, port = 8443, JNDI = 1099, server configuration = default.
I've checked the JBoss default config and it is using these port
numbers. I've also got Eclipse to successfully bind to JBoss over HTTP
using port 8080 and the same remaining settings.
Any ideas why Eclipse won't bind to JBoss when HTTPS is used?
Dave
Previous Topic:Intland Software is looking for a Java developer with Eclipse, VCS experience
Next Topic:Question on Eclipse Network Manager
Current Time: Sun Nov 09 05:01:14 EST 2025
Powered by FUDForum. Page generated in 0.02035 seconds
