Home » Eclipse Projects » Eclipse Platform » don't close an externally deleted file
don't close an externally deleted file [message #335999] Wed, 13 May 2009 04:40 Go to next message
Hi All,
On my fresh 3.4.2 install, I am finding that JSPs that get deleted
externally (say from Windows Explorer) are automatically closing in
Eclipse. Is there a setting to stop that behaviour?
Thanks for any advice!
Rob
Re: don't close an externally deleted file [message #336020 is a reply to message #335999] Wed, 13 May 2009 20:59 Go to previous message
Isn't there a JSP editor that ships with Eclipse Web Tools? I wonder if
you are using that. If so, you might have better luck asking on
eclipse.webtools.
Otherwise the standard text editors typically prompt you before closing
a deleted resource. I don't think there is a preference to
enable/disable that prompt.
Ben
Robert Mark Bram wrote:
> Hi All,
> Rob
Previous Topic:What is the difference between the eclipse packages and the SDK?
Next Topic:text copy/paste background annoying problem
Current Time: Fri Nov 21 08:19:09 EST 2025
Powered by FUDForum. Page generated in 1.03753 seconds
