Home » Eclipse Projects » Eclipse Platform » Tabbed Properties Image Leaks?
Tabbed Properties Image Leaks? [message #335957] Mon, 11 May 2009 11:01 Go to next message
We are tracking some image leaks that occur when closing / opening
editors. They seem to be coming from the icons on the properties tabs.
Sleak is reporting leaks of the images we contribute via the
org.eclipse.ui.views.properties.tabbed extension. Below I've pasted a
snippet of a stack trace showing where these images are allocated.
I would like to verify whether these images are being disposed of
properly. We are providing the icons, but I'm not sure it is our
responsibility to dispose of them. Is there something I'm missing or is
there a reason for not disposing of them?
Charlie
at org.eclipse.swt.graphics.Device.new_Object(Device.java:806)
at org.eclipse.swt.graphics.Resource.init(Resource.java:85)
at org.eclipse.swt.graphics.Image.<init>(Image.java:735)
org.eclipse.jface.resource.URLImageDescriptor.createImage(UR LImageDescriptor.java:162)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:227)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:205)
org.eclipse.ui.internal.views.properties.tabbed.view.TabDesc riptor. <init>(TabDescriptor.java:79)
org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyRegistry.readTabDescriptors(TabbedPropertyRegistry.ja va:364)
org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyRegistry.getAllTabDescriptors(TabbedPropertyRegistry. java:342)
org.eclipse.ui.internal.views.properties.tabbed.view.TabbedP ropertyRegistry.getTabDescriptors(TabbedPropertyRegistry.jav a:283)
org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPa ge.setInput(TabbedPropertySheetPage.java:695)
org.eclipse.ui.views.properties.tabbed.TabbedPropertySheetPa ge.selectionChanged(TabbedPropertySheetPage.java:538)
Re: Tabbed Properties Image Leaks? [message #335961 is a reply to message #335957] Mon, 11 May 2009 12:41 Go to previous messageGo to next message
That looks like a leak. Please open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
(the sooner, the better, as we're in 3.5 RC1)
PW
Paul Webster
Re: Tabbed Properties Image Leaks? [message #335962 is a reply to message #335961] Mon, 11 May 2009 14:06 Go to previous message
All set - https://bugs.eclipse.org/bugs/show_bug.cgi?id=275702
Charlie
Previous Topic:Can builder change delta?
Next Topic:Lost PDE resources
Current Time: Thu Jul 17 23:58:39 EDT 2025
Powered by FUDForum. Page generated in 0.04540 seconds
