Home » Eclipse Projects » Eclipse Platform » [Databinding] bind modify of text to boolean
[Databinding] bind modify of text to boolean [message #335952] Mon, 11 May 2009 10:02 Go to next message
I'm quite new to eclipse databinding.
I have a Text which is bind to model.
public static void bindTextToValue( Text text, Object object, String
propertyName, IValidator validator ) {
ISWTObservableValue textValue = SWTObservables.observeText( text,
SWT.Modify );
IObservableValue objectValue = BeansObservables.observeValue(
getRealm(), object, propertyName );
UpdateValueStrategy strategy = new UpdateValueStrategy();
strategy.setAfterGetValidator( validator );
getContext().bindValue( textValue, objectValue, strategy, strategy );
This works.
But now I want to bind the text also to a boolean value, to notify if
the text has changed.
I did it like that:
ISWTObservableValue targetObservableValue = SWTObservables.observeText(
text, SWT.Modify );
IObservableValue modelObservableValue = BeansObservables.observeValue(
this, "changed" );
getContext().bindValue( targetObservableValue, modelObservableValue );
I want that the boolean "changed" is set to "true" if the user modify
the text.
Is it possible to bind selveral things to one text?
Roland
Re: [Databinding] bind modify of text to boolean [message #335959 is a reply to message #335952] Mon, 11 May 2009 12:21 Go to previous messageGo to next message
Welcome to the party :)
> the text.
You need to customize your binding with update strategies to do that.
Assuming that the text field is the target and the changed property is
the model:
* Set your model-to-target update strategy's update policy to
POLICY_NEVER to make sure the binding is one-way
* Set your target-to-model update strategy's converter to a custom
converter that always returns Boolean.TRUE.
* Make sure this binding is created *after* the other one(s) that bind
to the text field. Otherwise your "changed" property will be set to
true before you form is even set up.
This is a brittle solution and it will break down in master-detail
forms. But hopefully it is enough to solve your current problem.
Yes, however you have to be careful about ripple effects. e.g. suppose
M1 and M2 are both bound to T:
* A change to T will update M1 and M2 at once.
* A change to M1 will update T, which will in turn update M2.
Be very careful not to create a diamond-shaped binding scenario or you
will likely get a stack overflow. e.g. suppose M1 binds to T1, T1 binds
to M2, M2 binds to T2, T2 binds to M1. An update to any of these could
end up sending the update round and round until the stack overflows.
Matthew
Re: [Databinding] bind modify of text to boolean [message #335975 is a reply to message #335959] Tue, 12 May 2009 07:55 Go to previous messageGo to next message
--------------030703080209030208070609
Hi Matthew,
Thank you very much. Your explanation really helped.
Now I have only one problem.
When I select the "saveButton", which was enabled when the "changed" was
set to "true", "changed" should set back to "false".
But I can't get it working.
I attached a little snippet.
name="TestSnippet.java"
Content-Disposition: inline;
filename="TestSnippet.java"
package org.eclipse.jface.examples.databinding.snippets;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.core.databinding.UpdateValueStrategy;
import org.eclipse.core.databinding.beans.PojoObservables;
import org.eclipse.core.databinding.conversion.IConverter;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.value.ComputedValue;
import org.eclipse.core.databinding.observable.value.IObservableVal ue;
import org.eclipse.jface.databinding.swt.ISWTObservableValue;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class TestSnippet {
static Person person = new Person("John", "Smith");
Display display = new Display();
Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
public void run() {
Display display = Display.getCurrent();
Shell shell = new Shell(display);
shell.setLayout(new RowLayout(SWT.VERTICAL));
Text first = new Text(shell, SWT.BORDER);
Text last = new Text(shell, SWT.BORDER);
Button button = new Button(shell, SWT.NONE);
button.setText("Save");
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
// save...
// here comes the binding
DataBindingContext context = new DataBindingContext();
// bind first to Person#firstName
ISWTObservableValue firstValue = SWTObservables.observeText(
first, SWT.Modify);
IObservableValue firstModelValue = PojoObservables
.observeValue(person, "firstName");
context.bindValue(firstValue, firstModelValue,
new UpdateValueStrategy(), new UpdateValueStrategy());
// bind last to Person#lastName
ISWTObservableValue lastValue = SWTObservables.observeText(
last, SWT.Modify);
IObservableValue lastModelValue = PojoObservables.observeValue(
person, "lastName");
context.bindValue(lastValue, lastModelValue,
// bind modify of first/last to dirty
IObservableValue needSavingValue = PojoObservables
.observeValue(person, "needSaving");
UpdateValueStrategy t2m = new UpdateValueStrategy();
t2m.setConverter(new IConverter() {
public Object convert(Object fromObject) {
return Boolean.TRUE;
public Object getFromType() {
return String.class;
public Object getToType() {
return Boolean.class;
context.bindValue(firstValue, needSavingValue, t2m,
UpdateValueStrategy.POLICY_NEVER));
context.bindValue(lastValue, needSavingValue, t2m,
// bind the button to dirty - enable when dirty
ISWTObservableValue enableValue = SWTObservables
.observeEnabled(button);
context.bindValue(enableValue, needSavingValue,
// TODO bind the selection of button to dirty
final ISWTObservableValue buttonselectValue = SWTObservables
.observeSelection(button);
ComputedValue value = new ComputedValue(Boolean.TYPE) {
protected Object calculate() {
return new Boolean(!((Boolean) buttonselectValue
.getValue()).booleanValue());
context.bindValue(value, needSavingValue,
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
static class Person {
private String firstName;
private String lastName;
boolean needSaving;
public Person(String firstName, String lastName) {
this.firstName = firstName;
this.lastName = lastName;
public void setFirstName(String firstName) {
System.err.println("firstName changed from '" + this.firstName
+ "' to '" + firstName + "'.");
public String getFirstName() {
return firstName;
public void setLastName(String lastName) {
System.err.println("lastName changed from '" + this.lastName
+ "' to '" + lastName + "'.");
public String getLastName() {
return lastName;
public void setNeedSaving(boolean needSaving) {
System.err.println("needSaving changed from '" + this.needSaving
+ "' to '" + needSaving + "'.");
this.needSaving = needSaving;
public boolean isNeedSaving() {
return needSaving;
--------------030703080209030208070609--
Re: [Databinding] bind modify of text to boolean [message #335983 is a reply to message #335975] Tue, 12 May 2009 14:17 Go to previous messageGo to next message
Roland wrote:
> Hi Matthew,
In the event handler of the Save button, it will need to set the model
value back to false [call setNeedSaving(false)]. As long as you've set
up the binding correctly (bi-directional), that should automatically
make the button disabled again.
Hope this helps,
Eric
Re: [Databinding] bind modify of text to boolean [message #336013 is a reply to message #335983] Wed, 13 May 2009 11:40 Go to previous message
Thanks it works well now.
Roland
Eric Rizzo schrieb:
> Roland wrote:
>> Hi Matthew,
>> was set to "true", "changed" should set back to "false".
> Hope this helps,
> Eric
Previous Topic:How do I manually drop plugins into an eclipse install in 3.5M7?
Next Topic:What is the difference between the eclipse packages and the SDK?
Current Time: Sun Aug 31 13:46:52 EDT 2025
Powered by FUDForum. Page generated in 0.03986 seconds
