Home » Eclipse Projects » Eclipse Platform » workspace settings
workspace settings [message #335944] Mon, 11 May 2009 01:53 Go to next message
using Galileo M6.
When creating a new workspace, how do I transfer all my setting from the old
one? I mean the formatting settings, the templates I wrote, run/debug
configurations, etc...
Zohar
Re: workspace settings [message #335950 is a reply to message #335944] Mon, 11 May 2009 09:30 Go to previous message
You could just use your old workspace. Its backwards compatible.
If you want to have a new workspace, you can Export your preferences
(File->Export->General->Preferences) and then import them into the new one.
I think the only way you can port your run configurations is to change
them to be persisted in a project (see Common tab -> Save As on the
configuration itself). Otherwise they are just metadata in a workspace.
HTH
Ben
zohar wrote:
> Hello,
> using Galileo M6.
> old one? I mean the formatting settings, the templates I wrote,
> run/debug configurations, etc...
> Zohar
Previous Topic:can't see text cursor
Next Topic:[DataBinding] Databinding a ListViewer to a model list
Current Time: Thu Oct 30 14:40:40 EDT 2025
Powered by FUDForum. Page generated in 0.58177 seconds
