| Core expression, adapt to inner class [message #335871] |
Thu, 07 May 2009 10:24  |
Hey,
I'm trying to use the <adapt> element in a core expression, where the
target type is an inner class. So that looks like:
<activeWhen>
<and>
<count
value="1">
</count>
<iterate>
<adapt type="com.example.Outer.Inner">
</adapt>
</iterate>
</and>
</activeWhen>
That doesn't work. I also tried type="com.example.Outer$Inner", doesn't
work either.
Using type="java.lang.Object" and then adapting programatically inside
the handler's execute method works fine for test selections, so I'm sure
I have some objects for which the handler should be active..
Hope that someone can help.
Felix
FUDForum. Page generated in 0.04343 seconds
