Home » Eclipse Projects » Eclipse Platform » ContentOutline is not shown in Window menu
ContentOutline is not shown in Window menu [message #335847] Tue, 05 May 2009 04:31 Go to next message
Hi all,
I have an RCP application with one single perspective. Now it should
display in the Window -> Show View a shortcut to the outline view. I've
made this as follows:
<extension point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension targetID="my.own.package.MyPerspective">
<viewShortcut
id="org.eclipse.ui.views.ContentOutline">
</viewShortcut>
</perspectiveExtension>
</extension>
The Content Outline is not shown as shortcut in the Show View submenu. I
can only get it from Other... submenu. How can I make it work?
TIA,
Ralf.
Re: ContentOutline is not shown in Window menu [message #335851 is a reply to message #335847] Tue, 05 May 2009 07:46 Go to previous messageGo to next message
After adding the perspectiveExtension, you need to reset your
perspective if it was already visible.
PW
Paul Webster
Re: ContentOutline is not shown in Window menu [message #335852 is a reply to message #335851] Tue, 05 May 2009 08:11 Go to previous message
> PW
ah, thanks, that helped!
R.
Previous Topic:ScrolledForm with TableViewer scroll problem
Next Topic:Per-user plugin/dependencies broken between 3.4.1->3.4.2 (and beyond)
Current Time: Sat Jul 19 01:22:11 EDT 2025
Powered by FUDForum. Page generated in 0.03995 seconds
