Home » Language IDEs » AspectJ » multiple formal parameters?
multiple formal parameters? [message #34081] Fri, 16 April 2004 06:16 Go to next message
I am frustrated - I don't get it!
I want to specify an advice that has TWO parameters and I need access
to BOTH parameters in the advice.
I was able to phrase that as an "anonymous" pointcut (I think that's
the name for something like this):
before(IEvent evt, boolean flag): target(evt) && call(*
IEvent.setHandled(boolean)) && args(flag) {
But now I would like to specify this as a NAMED pointcut (1st to make
this more readable and 2nd to reuse the pointcut in more than one
advice):
I defined the pointcut:
pointcut eventSetHandled(IEvent evt, boolean flag): target(evt) &&
call(* IEvent.setHandled(boolean)) && args(flag);
And now I want to specify the advice. But how do I phrase this? I
tried:
before(IEvent evt, boolean flag): eventSetHandled(IEvent, boolean)
before(IEvent evt, boolean flag): eventSetHandled(IEvent evt,
boolean flag) { ... }
before(IEvent evt, boolean flag): eventSetHandled(evt, flag) {
None of the above work, i.e. all variants just yield compile errors!
How do I phrase this? What do I need to specify to get hold of more
than a single parameter of a named pointcut??? Or is this not possible
at all?
Alas, all the examples given in the AspectJ manual only show a single
parameter...
Michael
Re: multiple formal parameters? [message #34150 is a reply to message #34081] Fri, 16 April 2004 08:13 Go to previous messageGo to next message
Originally posted by: clemas.uk.ibm.com
What you want to do is possible. The third variant you quote below works.
i.e. this works for me:
pointcut eventSetHandled(IEvent evt,boolean flag):
target(evt) &&
args(flag);
before(IEvent evt, boolean flag): eventSetHandled(evt,flag) {
System.err.println("In advice! evt="+evt+" flag="+flag);
And I'd probably drop the type reference in the call() PCD since you are
using target(). If you want other examples of multiple parameters, take a
look at the Enterprise AOP tutorial presentation downloadable from
http://www.newaspects.com/presentations
Andy.
> advice):
> tried:
> at all?
> parameter...
> Michael
Re: multiple formal parameters? [message #34183 is a reply to message #34150] Fri, 16 April 2004 09:09 Go to previous message
Indeed - the third variant works.In fact I got this compiled just
before I saw your append, so I seem to get a first "feeling" for this
somewhat strange syntax. But why it didn't compile before remains
beyond me.
Anyway - thanks a lot! I highly appreciate your help!
And thanks for the link, too! Already on the way to the printer...
Michael
PS.: I'm still puzzled about this exception example - see my other
thread...
"Andy Clement" <clemas@uk.ibm.com> wrote in message
news:c5oili$1ja$1@eclipse.org...
works.
> target(evt) &&
> args(flag);
are
take a
> Andy.
access
that's
make
> > advice):
> > tried:
boolean)
errors!
more
possible
> > at all?
single
> > parameter...
> > Michael
Re: multiple formal parameters? [message #578484 is a reply to message #34081] Fri, 16 April 2004 08:13 Go to previous message
target(evt) &&
args(flag);
Andy.
> advice):
> tried:
> at all?
> parameter...
> Michael
Re: multiple formal parameters? [message #578506 is a reply to message #34150] Fri, 16 April 2004 09:09 Go to previous message
beyond me.
Michael
thread...
works.
> target(evt) &&
> args(flag);
are
take a
> Andy.
access
that's
make
> > advice):
> > tried:
boolean)
errors!
more
possible
> > at all?
single
> > parameter...
> > Michael
Previous Topic:multiple formal parameters?
Next Topic:Framework for supporting java based languages in eclipse?
Current Time: Wed Nov 05 22:02:45 EST 2025
Powered by FUDForum. Page generated in 0.05168 seconds
