Home » Eclipse Projects » Eclipse Platform » Help required on org.eclipse.osgi
Help required on org.eclipse.osgi [message #335836] Mon, 04 May 2009 00:03 Go to next message
I have written a plugin that uses some resources on runtime. These
resources are bundled within the plugin jar itself.
As some of these resources were missing at the actual runtime, I did some
investigation and found that resources from my plugin jar has been copied
to a RAD specific folder at location "C:Program
FilesIBMSDPconfigurationorg.eclipse.osgibundles"
Also, the resources are not complete. That is, this folder has copied only
a few resources from my plugin, not all that I want.
This causes an inconsistent behaviour of my plugin.
Does anyone know what the underlying problem can be ??
Re: Help required on org.eclipse.osgi [message #335905 is a reply to message #335836] Fri, 08 May 2009 09:54 Go to previous message
Originally posted by: jacek.pospychala.pl.ibm.com
Hi Shilpa,
Eclipse uses the configuration\org.eclipse.osgi\bundles area to cache
plug-in contents such as JARs or OS libraries, that normally cannot be
accessed from JAR - e.g. JAR in JAR, or DLL in JAR. Only contents of
Plug-in classpath are extracted and it's all up-to plug-in developer
configuration.
Eclipse also transparently handles access to resources in both locations.
Similar problems are usually caused by incorrect access to resources in
plug-in, for example using classloader instead of Bundle.getEntry() to
load resources.
shilpa pisze:
> some investigation and found that resources from my plugin jar has been
> copied to a RAD specific folder at location "C:Program
> only a few resources from my plugin, not all that I want.
Previous Topic:Eclipse project structure
Next Topic:Update-Site over https
Current Time: Tue Dec 02 05:49:26 EST 2025
Powered by FUDForum. Page generated in 0.05208 seconds
