| SVN Updates disconnected projects from repo [message #335820] |
Fri, 01 May 2009 09:57  |
I woke up this morning and found an "updates available" window displayed
in the lower right corner of the Eclipse window. I clicked the info box,
and saw noticed updates for SVN connector. After the updates installed,
Eclipse restarted, and after that, all my projects are disconnected from
the repo, and I get entries in error log.
Is there something I can do to repair this?
eclipse.buildId=M20090211-1700
java.version=1.6.0_13
Command-line arguments: -os win32 -ws win32 -arch x86 -data
c:/EclipseWorkspace/Trunk
Error
Fri May 01 06:17:52 GMT-07:00 2009
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
java.lang.NoSuchMethodError:
org.eclipse.team.svn.core.connector.SVNChangeStatus.<init> (Ljava/lang/String;Ljava/lang/String;IJJJLjava/lang/String;I IIIZZLjava/lang/String;Ljava/lang/String;Ljava/lang/String;L java/lang/String;JZLjava/lang/String;Ljava/lang/String;Ljava /lang/String;JLorg/eclipse/team/svn/core/connector/SVNLock;J JILjava/lang/String;)V
org.tigris.subversion.javahl.ConversionUtility.convert(Conve rsionUtility.java:118)
org.polarion.team.svn.connector.javahl.JavaHLConnector.statu s(JavaHLConnector.java:400)
org.eclipse.team.svn.core.extension.factory.ThreadNameModifi er.status(ThreadNameModifier.java:608)
at org.eclipse.team.svn.core.utility.SVNUtility.status(SVNUtili ty.java:289)
org.eclipse.team.svn.core.utility.SVNUtility.getSVNInfoForNo tConnected(SVNUtility.java:762)
org.eclipse.team.svn.core.SVNTeamProvider.uploadRepositoryRe source(SVNTeamProvider.java:241)
org.eclipse.team.svn.core.SVNTeamProvider.connectToProject(S VNTeamProvider.java:172)
org.eclipse.team.svn.core.SVNTeamProvider.getRepositoryResou rce(SVNTeamProvider.java:71)
org.eclipse.team.svn.core.svnstorage.SVNRemoteStorage.asRepo sitoryResource(SVNRemoteStorage.java:421)
org.eclipse.team.svn.ui.history.SVNHistoryPage.showHistory(S VNHistoryPage.java:268)
org.eclipse.team.svn.ui.history.SVNHistoryPage.inputSet(SVNH istoryPage.java:446)
at org.eclipse.team.ui.history.HistoryPage.setInput(HistoryPage .java:59)
org.eclipse.team.internal.ui.history.GenericHistoryView.show HistoryPageFor(GenericHistoryView.java:738)
org.eclipse.team.internal.ui.history.GenericHistoryView.show History(GenericHistoryView.java:969)
org.eclipse.team.internal.ui.history.GenericHistoryView.edit orActivated(GenericHistoryView.java:892)
org.eclipse.team.internal.ui.history.GenericHistoryView.setF ocus(GenericHistoryView.java:598)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:325)
at org.eclipse.ui.internal.WorkbenchPage$3.run(WorkbenchPage.ja va:622)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:617)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3487)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:3034)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:272)
org.eclipse.ui.internal.presentations.PresentablePart.setFoc us(PresentablePart.java:192)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:94)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:267)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:272)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .handleMouseDown(AbstractTabFolder.java:342)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder $3.mouseDown(AbstractTabFolder.java:79)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:179)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
| Re: SVN Updates disconnected projects from repo [message #335821 is a reply to message #335820] |
Fri, 01 May 2009 10:08  |
It is an issue with the latest update for SVN.
The SVN team has yet to post a proper fix to the update site, either fixing
the issue or reverting to the last known good configuration.
Please see the subversive newsgroup for further info.
"Michael Giroux" <michael_giroux@choicehotels.com> wrote in message
news:8ca2184a176d8dee850364f3f72edd17$1@www.eclipse.org...
>I woke up this morning and found an "updates available" window displayed in
>the lower right corner of the Eclipse window. I clicked the info box, and
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03183 seconds
