Home » Eclipse Projects » Eclipse Platform » Can't get menu item with handler working properly
Can't get menu item with handler working properly [message #335787] Wed, 29 April 2009 16:31 Go to next message
I'm trying to move some code using ActionSets to the newer ui menus,
commands, and handlers but it isn't going well.
First of all, I have a menu item I want to add to
menu:project?after=additions. I specify checkEnabled true so it won't be
visible when not enabled.
I have a command "Run Command" set up.
I try and set up a handler. What I want is to have the handler
active/enabled whenever an IResource is selected that is part of a project
with projectNature=X. I tried the iterate operator and with test for
org.eclipse.core.resources.projectNature of X, but I couldn't get this to
work.
So I backed off and tried a simpler check for my handler so it is both
active/enabled when
with selection
count = 1
iterate and
adapt org.eclipse.core.resources.IResource
This allows me to see my menu item if it is the project or a folder within
a C/C++ project and I can click on the menu item and have it execute
successfully.
The problem is that I can only click on it once. The next time I bring up
the Project menu, it is gone whether I select the project or folder, even
if it just worked previously. My handler code is hardcoded to return true
for isenabled() and ishandled() and returns null from execute() as
specified in the docs.
Can anybody suggest how I should do this based on my original desired
behavior and/or why the menu item disappears after the first click? There
are no errors in the error log. I am using Eclipse 3.4.1.
Re: Can't get menu item with handler working properly [message #335789 is a reply to message #335787] Wed, 29 April 2009 16:52 Go to previous messageGo to next message
If you haven't already, try turning on tracing to get more insight into
what is happening.
http://wiki.eclipse.org/Platform_Command_Framework#Tracing_O ption
You can configure it right from your launch configuration on the Tracing
tab.
-Ben
> be visible when not enabled.
> project with projectNature=X. I tried the iterate operator and with
> test for org.eclipse.core.resources.projectNature of X, but I couldn't
> get this to work.
> active/enabled when
> with selection
> count = 1
> iterate and
> within a C/C++ project and I can click on the menu item and have it
> execute successfully.
> up the Project menu, it is gone whether I select the project or folder,
> even if it just worked previously. My handler code is hardcoded to
> return true for isenabled() and ishandled() and returns null from
> execute() as specified in the docs.
> There are no errors in the error log. I am using Eclipse 3.4.1.
Re: Can't get menu item with handler working properly [message #335790 is a reply to message #335789] Wed, 29 April 2009 17:39 Go to previous messageGo to next message
Ok, thanks for the info. I have a trace but I don't understand how to
interpret it. It found the original handler, ran the autoconf command as
asked, then switched to no handler ??, then back to a specific instance of
the autoconf handler again at the end, but for some reason doesn't allow
the menu item to show up again. Any suggestions for further tracing?
Configuration location:
file:/home/jjohnstn/workspace-autotools/.metadata/.plugins/o rg.eclipse.pde.core/Autotools_testing_configuration/
Configuration file:
file:/home/jjohnstn/workspace-autotools/.metadata/.plugins/o rg.eclipse.pde.core/Autotools_testing_configuration/config.i ni
loaded
Install location:
file:/usr/lib/eclipse/
Framework located:
file:/usr/lib/eclipse/plugins/org.eclipse.osgi_3.4.2.R34x_v2 0080826-1230.jar
Framework classpath:
Splash location:
/usr/lib/eclipse/plugins/org.fedoraproject.ide.platform_3.4. 1/splash.bmp
Debug options:
file:/home/jjohnstn/workspace-autotools/.metadata/.plugins/o rg.eclipse.pde.core/Autotools_testing_configuration/.options
loaded
Time to load bundles: 22
Starting application: 2809
BINDINGS >>> Clearing cache
CONTEXTS >>> register shell 'Shell {Fedora Eclipse}' as window
BINDINGS >>> Cache miss
BINDINGS >>> There are 0 deletion markers
SOURCES >>> ASSP:lastActiveShell: null
SOURCES >>> ASSP:lastActiveWorkbenchWindowShellnull
SOURCES >>> Active shell changed to Shell {C/C++ - sources/configure.in -
Fedora Eclipse}
SOURCES >>> Active workbench window changed to
org.eclipse.ui.internal.WorkbenchWindow@38fb59
SOURCES >>> Active workbench window shell changed to Shell {C/C++ -
sources/configure.in - Fedora Eclipse}
SOURCES >>> Active workbench window coolbar visibility true
SOURCES >>> Active workbench window perspective bar visibility true
SOURCES >>> Active workbench window status line visibility true
EVALUATION >>> start source changed: [activeShell,
activeWorkbenchWindowShell, activeWorkbenchWindow.activePerspective,
activeWorkbenchWindow.isStatusLineVisible,
activeWorkbenchWindow.isCoolbarVisible,
activeWorkbenchWindow.isPerspectiveBarVisible, activeWorkbenchWindow]
EVALUATION >>> end source changed: [activeShell,
CONTEXTS >>> [org.eclipse.ui.contexts.dialogAndWindow]
CONTEXTS >>> [org.eclipse.mylyn.doc.actionSet,
org.eclipse.mylyn.tasks.ui.navigation,
org.eclipse.ui.contexts.dialogAndWindow,
org.eclipse.cdt.ui.CodingActionSet]
org.eclipse.mylyn.context.ui.actionSet, org.eclipse.cdt.ui.CodingActionSet]
org.eclipse.debug.ui.breakpointActionSet,
org.eclipse.cdt.ui.NavigationActionSet,
org.eclipse.ui.edit.text.actionSet.annotationNavigation,
org.eclipse.cdt.ui.buildConfigActionSet,
org.eclipse.debug.ui.launchActionSet,
org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo,
org.eclipse.cdt.ui.CodingActionSet,
org.eclipse.linuxtools.changelog.actionSet]
org.eclipse.ui.edit.text.actionSet.presentation,
org.eclipse.cdt.ui.CodingActionSet, org.eclipse.ui.actionSet.keyBindings,
org.eclipse.cdt.make.ui.makeTargetActionSet,
org.eclipse.ui.edit.text.actionSet.navigation,
org.eclipse.ui.externaltools.ExternalToolsSet,
org.eclipse.ui.NavigateActionSet, org.eclipse.cdt.ui.NavigationActionSet,
org.eclipse.cdt.ui.CodingActionSet, org.eclipse.ui.actionSet.openFiles,
org.eclipse.ui.contexts.window,
org.eclipse.ui.cheatsheets.actionSet,
org.eclipse.search.searchActionSet,
org.eclipse.cdt.ui.OpenActionSet, org.eclipse.debug.ui.launchActionSet,
org.eclipse.ui.actionSet.keyBindings, rpmEditor.actionSet,
CONTEXTS >>> [org.eclipse.mylyn.tasks.ui.navigation,
org.eclipse.cdt.ui.NavigationActionSet, org.eclipse.ui.NavigateActionSet,
org.eclipse.ui.cheatsheets.actionSet, org.eclipse.cdt.ui.SearchActionSet,
org.eclipse.ui.contexts.window, org.eclipse.mylyn.context.ui.actionSet,
org.eclipse.linuxtools.changelog.actionSet,
org.eclipse.mylyn.doc.actionSet, org.eclipse.debug.ui.launchActionSet,
org.eclipse.cdt.ui.OpenActionSet, org.eclipse.cdt.ui.buildConfigActionSet,
org.eclipse.debug.ui.breakpointActionSet]
CONTEXTS >>> [org.eclipse.cdt.ui.CElementCreationActionSet,
SOURCES >>> Action sets changed to [Task Context, Build Configuration,
Task Navigation, C/C++ Navigation, Make Actions, C/C++ Open Actions,
ChangeLog Action Set, Annotation Navigation, Editor Presentation, Tasks
Help, Keyboard Shortcuts, C/C++ Search, Editor Commands, Open Files, C/C++
Element Creation, Cheat Sheets, Launch, Search, External Tools, Convert
Line Delimiters, Breakpoints, Resource Navigation, Editor Navigation,
C/C++ Coding]
EVALUATION >>> start source changed: [activeActionSets]
EVALUATION >>> end source changed: [activeActionSets]
SOURCES >>> Contexts changed to
EVALUATION >>> start source changed: [activeContexts]
EVALUATION >>> end source changed: [activeContexts]
SOURCES >>> Active part changed to
org.eclipse.linuxtools.cdt.autotools.ui.editors.AutoconfEdit or @de1b36
SOURCES >>> Active part id changed to
org.eclipse.linuxtools.cdt.autotools.editor.autoconf
SOURCES >>> Active site changed to
PartSite(id=org.eclipse.linuxtools.cdt.autotools.editor.auto conf,pluginId=org.eclipse.linuxtools.cdt.autotools,registere dName=Autoconf
Editor,hashCode=22848050)
SOURCES >>> Active editor changed to
SOURCES >>> Active editor id changed to
EVALUATION >>> start source changed: [activePartId, showInSelection,
activePart, activeSite, activeEditorId, showInInput, activeEditor]
EVALUATION >>> end source changed: [activePartId, showInSelection,
org.eclipse.linuxtools.cdt.autotools.ui.editor.scope,
SOURCES >>> Selection changed to
org.eclipse.jface.text.TextSelection@1023565
EVALUATION >>> start source changed: [selection]
EVALUATION >>> end source changed: [selection]
SOURCES >>> ASSP: passOnEvent: StyledText {}
SOURCES >>> ASSP: passOnEvent: Canvas {}
SOURCES >>> ASSP: passOnEvent: Composite {}
Application Started: 12901
SOURCES >>> ASSP: passOnEvent: Tree {}
org.eclipse.ui.navigator.CommonNavigator@1a3ae73
org.eclipse.ui.navigator.ProjectExplorer
PartSite(id=org.eclipse.ui.navigator.ProjectExplorer,pluginI d=org.eclipse.ui.navigator.resources,registeredName=Project
Explorer,hashCode=2349183)
BINDINGS >>> Cache hit
SOURCES >>> Selection changed to <empty selection>
SOURCES >>> Selection changed to [P/sources]
HANDLERS >>>
Command('org.eclipse.linuxtools.cdt.autotools.command.autoco nf') has
changed to 'org.eclipse.linuxtools.cdt.autotools.actions.AutoconfHandle r'
as its handler
SOURCES >>> Active part changed to null
SOURCES >>> Active part id changed to null
SOURCES >>> Active site changed to null
SOURCES >>> Active editor changed to null
SOURCES >>> Active editor id changed to null
SOURCES >>> Action sets changed to []
SOURCES >>> ASSP:lastActiveShell: Shell {C/C++ - sources/configure.in -
Fedora Eclipse}
SOURCES >>> ASSP:lastActiveWorkbenchWindowShellShell {C/C++ -
SOURCES >>> Active shell changed to Shell {Running autoconf in
/home/jjohnstn/runtime-Autotools_testing_configuration/sourc es }
SOURCES >>> Active workbench window changed to null
SOURCES >>> Active workbench window shell changed to null
activeWorkbenchWindowShell, activeWorkbenchWindow]
org.eclipse.debug.ui.launchActionSet, org.eclipse.cdt.ui.OpenActionSet,
org.eclipse.ui.externaltools.ExternalToolsSet]
org.eclipse.ui.NavigateActionSet, org.eclipse.ui.actionSet.keyBindings,
rpmEditor.actionSet, org.eclipse.ui.cheatsheets.actionSet,
org.eclipse.cdt.ui.SearchActionSet, org.eclipse.ui.contexts.window,
CONTEXTS >>> [org.eclipse.ui.contexts.dialog,
org.eclipse.ui.actionSet.openFiles, org.eclipse.search.searchActionSet,
org.eclipse.cdt.ui.OpenActionSet, org.eclipse.ui.actionSet.openFiles,
org.eclipse.ui.NavigateActionSet, rpmEditor.actionSet,
org.eclipse.ui.contexts.window, org.eclipse.cdt.ui.OpenActionSet,
org.eclipse.ui.contexts.dialogAndWindow, org.eclipse.ui.NavigateActionSet,
org.eclipse.search.searchActionSet]
org.eclipse.ui.contexts.dialogAndWindow, rpmEditor.actionSet,
org.eclipse.ui.actionSet.openFiles, org.eclipse.search.searchActionSet]
org.eclipse.cdt.ui.OpenActionSet, org.eclipse.search.searchActionSet]
org.eclipse.cdt.ui.SearchActionSet, org.eclipse.cdt.ui.OpenActionSet,
org.eclipse.cdt.ui.SearchActionSet, org.eclipse.cdt.ui.OpenActionSet]
org.eclipse.cdt.ui.SearchActionSet]
SOURCES >>> Contexts changed to [org.eclipse.ui.contexts.dialog,
SOURCES >>> Selection changed to null
HANDLERS >>>
changed to no handler
SOURCES >>> ASSP: passOnEvent: Button {OK}
SOURCES >>> Contexts changed to [org.eclipse.ui.contexts.dialog]
CONTEXTS >>> [org.eclipse.ui.contexts.dialog]
SOURCES >>> Contexts changed to []
CONTEXTS >>> []
SOURCES >>> ASSP:lastActiveShell: Shell {*Disposed*}
Fedora Eclipse}
CONTEXTS >>> [org.eclipse.ui.contexts.dialogAndWindow,
org.eclipse.mylyn.doc.actionSet]
org.eclipse.ui.contexts.dialogAndWindow, org.eclipse.mylyn.doc.actionSet]
org.eclipse.ui.contexts.dialogAndWindow, org.eclipse.mylyn.doc.actionSet,
org.eclipse.mylyn.context.ui.actionSet, org.eclipse.mylyn.doc.actionSet,
org.eclipse.ui.actionSet.keyBindings, org.eclipse.ui.contexts.window,
org.eclipse.ui.cheatsheets.actionSet, org.eclipse.ui.contexts.window,
Re: Can't get menu item with handler working properly [message #335793 is a reply to message #335790] Wed, 29 April 2009 20:01 Go to previous messageGo to next message
If nothing else, turn off some of the tracing that you don't care about,
such as contexts and bindings. There is a lot of output there.
Did you specify your command in "handlers.verbose.commandId"? I've never
tried it myself but suspect that will give you more detailed information
about how the evaluation process is resulting in a deactivated handler
for that particular command.
Every time I've had this type of unexpected handler disablement, its
been something in my code or my handler definition. Bear in mind that
your subclass of AbstractHandler is almost certainly not the problem; if
the handler isn't active, that just means the declarative conditions
don't match up. Keep dumbing them down until it always works, then tweak
from there.
Finally, if you have a scenario that is isolated and reproducible, it
could be a bug. You could always try against 3.4.2 or the latest 3.5 builds.
Cheers
Ben
> as asked, then switched to no handler ??, then back to a specific
> instance of the autoconf handler again at the end, but for some reason
> doesn't allow the menu item to show up again. Any suggestions for
> further tracing?
Re: Can't get menu item with handler working properly [message #335805 is a reply to message #335787] Thu, 30 April 2009 13:28 Go to previous messageGo to next message
You might have encountered
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249442 where the menu item
disappears and never comes back.
That is fixed in 3.5 (if you test against a 3.5 M6 build you could
confirm this is your problem).
PW
Paul Webster
Re: Can't get menu item with handler working properly [message #335813 is a reply to message #335793] Thu, 30 April 2009 15:57 Go to previous messageGo to next message
It appears to be the checkEnabled feature of the menu item. Perhaps it
gets set off when the handler gets reset to no handler and never reset on
again. When I add my own VisibleWhen logic, that works consistently.
I do have a question though. How do I get a project nature test for
subfolders and files of a project? A projectNature test works when the
project itself is selected, but not for any child resources like folders
or files. Should I adapt/with/resolve?? an IResource to an IProject, then
do the test org.eclipse.core.resources.projectNature=xxx? It isn't very
clear in the documentation. I can open a separate thread for this
question if you don't know off-hand.
>> further tracing?
Re: Can't get menu item with handler working properly [message #335814 is a reply to message #335805] Thu, 30 April 2009 15:59 Go to previous messageGo to next message
> PW
Thanks for the info. It was a bug with checkEnabled. I have since
switched to explicitly adding my visibleWhen logic. I still don't know
how to test the projectNature of an IResource that is a child of the
project, but I am one step closer.
Re: Can't get menu item with handler working properly [message #335816 is a reply to message #335813] Thu, 30 April 2009 17:06 Go to previous message
I figured it out. I have to do:
count=1
iterate and
test org.eclipse.core.resources.projectNature=myNature
I am using the CDT so I guess the adapt is needed to translate from the
CDT constructs to an IResource upon which I can test for the projectNature.
Previous Topic:[CNF] Enablement with resources
Next Topic:Listening to ResourceAttributes
Current Time: Fri Oct 17 11:18:42 EDT 2025
Powered by FUDForum. Page generated in 0.07832 seconds
