Home » Eclipse Projects » Eclipse Platform » New databinding idiom
New databinding idiom [message #335780] Wed, 29 April 2009 09:26 Go to next message
Originally posted by: gaston.tonietti.teracode.com
Hi all,
I've seen here: http://fire-change-event.blogspot.com/ some databinding
examples using new API from 3.5 builds, and I liked it too much.
So the question is, if I want to migrate my old databinding code to the new
style, where can I start reading some documentation?
Maybe a migration path or an old/new comparative table or any other kind of
documentation about the new way of doing databinding.
Thanks a lot.
Gaston.
Re: New databinding idiom [message #335782 is a reply to message #335780] Wed, 29 April 2009 11:21 Go to previous messageGo to next message
Gaston,
See responses below.
I'm glad you like it!
I'm assuming you're talking about the properties API vs the existing
observable factory API, e.g.:
BeansObservables.observeValue(bean, "name")
vs.
BeanProperties.value("name").observe(bean)
First let me say that you don't *have* to migrate your code; existing
code will continue to work without modification. However if you want to
use the property API as a matter of personal taste then you could
certainly do that.
If you could provide some examples of existing code that you want to
migrate, I'd be happy to convert it to use the IProperty APIs.
Other than a case-by-case basis the only other thing I'd recommend you
look at is the ViewerSupport class, which uses properties to make
binding a viewer very simple.
Matthew
Re: New databinding idiom [message #335784 is a reply to message #335782] Wed, 29 April 2009 14:06 Go to previous messageGo to next message
I understand it is more an API extension than a replacement, so it is just
as you said, I want to use it when possible as I like it more.
I'm not concerning with viewers that much as I have a few views (one tree
and some tables) but I will take a look at ViewerSupport for sure since it
seems very powerful.
My main concern is for forms, I make extensive use of eclipse forms in my
application's editors, so I like the new Property API for binding form
fields with domain objects properties.
So, I think I should pay special attention to WidgetProperties and
BeanProperties clases, also to DuplexingObservableValue as my editors
support bulk edition.
Is it right?
Thanks in advance.
Gaston.
Matthew Hall wrote:
> Gaston,
> vs.
>> new style, where can I start reading some documentation?
> certainly do that.
>> of documentation about the new way of doing databinding.
> Matthew
Re: New databinding idiom [message #335786 is a reply to message #335782] Wed, 29 April 2009 16:01 Go to previous messageGo to next message
Matthew, ideally you would write at least a new&noteworthy paragraph about
the new API...
Boris
"Matthew Hall" <matthall@woodcraftmill.com> wrote in message
news:gt9ra5$2vo$1@build.eclipse.org...
> Gaston,
> vs.
> First let me say that you don't *have* to migrate your code; existing code
> will continue to work without modification. However if you want to use
> the property API as a matter of personal taste then you could certainly do
> that.
> look at is the ViewerSupport class, which uses properties to make binding
> Matthew
Re: New databinding idiom [message #335791 is a reply to message #335786] Wed, 29 April 2009 17:42 Go to previous messageGo to next message
That's a good reminder, when is the deadline for M7?
Matthew
> the new API...
> Boris
>> Gaston,
>> vs.
>> that.
>> Matthew
Re: New databinding idiom [message #335792 is a reply to message #335784] Wed, 29 April 2009 18:09 Go to previous message
I've been doing the same thing, although I tend to migrate existing code
as I go rather than trying to do everything at once.
It sounds like you've got a good handle on it. The only thing I would
suggest is to familiarize yourself with all of the new property factory
classes:
org.eclipse.core.databinding.BindingProperties -
DataBindingContext#validationStatusProviders, DBC#bindings,
Binding#model, Binding#target, ValidationStatusProvider#models,
VSP#targets, VSP#validationStatus
org.eclipse.core.databinding.property.Properties - general purpose
properties such as self properties, the value of an IObservableValue.
org.eclipse.core.databinding.beans.BeanProperties - beans
org.eclipse.core.databinding.beans.PojoProperties - pojos
org.eclipse.jface.databinding.swt.WidgetProperties - SWT widgets
org.eclipse.jface.databinding.util.JFaceProperties - properties using
the JFace IPropertyChangeListener listener interface
org.eclipse.jface.databinding.viewers.CellEditorProperties -
CellEditor#control property, useful for building nested properties e.g.
TextCellEditor.control.text. Use in conjunction with
ObservableValueEditingSupport.create()
org.eclipse.jface.databinding.viewers.ViewerProperties - Viewer single-
or multiple-selection, checked elements, filters, input
Matthew
Previous Topic:Reusing the Tabbed Properties
Next Topic:Unable to launch Eclipse on SLES 11 (PPC) from remote X Client
Current Time: Tue Jul 22 15:32:50 EDT 2025
Powered by FUDForum. Page generated in 0.03725 seconds
