Home » Eclipse Projects » Eclipse Platform » Best practice: Working on Eclipse CVS stuff
Best practice: Working on Eclipse CVS stuff [message #335659] Mon, 20 April 2009 07:45 Go to next message
Hello.
As I just started hacking a bit on the Eclipse stuff, I often encounter
the following problem.
I fetched a plug-in I want to work on from the Eclipse CVS. Now I make
some changes, but want to test the original version again.
One way would be to create a patch, revert all changes, test the
original code, apply the patch again (quite unhandy).
I know, a good solution would be a DVCS, but we are not there yet ;-)
How do you jump between your own version and the original one from the
CVS? Or do checkin the code in your own VCS. But then there is the
problem again to synchronize with the Eclipse CVS.
Kai
Re: Best practice: Working on Eclipse CVS stuff [message #335661 is a reply to message #335659] Mon, 20 April 2009 09:23 Go to previous messageGo to next message
I just found out that there is a local history. I never noticed that
before (so many features in Eclipse :-)). This seems to be very helpful
for that task.
Kai Schlamp schrieb:
> Hello.
> Best regards,
> Kai
Re: Best practice: Working on Eclipse CVS stuff [message #335677 is a reply to message #335659] Tue, 21 April 2009 00:39 Go to previous messageGo to next message
"Kai Schlamp" <schlamp@gmx.de> wrote in message
news:gshn93$dlt$1@build.eclipse.org...
> Hello.
> One way would be to create a patch, revert all changes, test the original
As you discovered, local history is one way around this.
But actually, I prefer to do exactly what you described. The reason is that
then I have the patch, so others can review it and I can post it in the bug
report. It only takes a few seconds to revert or re-apply a patch, in most
cases; I don't find it un-handy at all.
Re: Best practice: Working on Eclipse CVS stuff [message #335684 is a reply to message #335659] Tue, 21 April 2009 11:51 Go to previous messageGo to next message
Kai Schlamp wrote:
> Hello.
In addition to Local History and Patches (which I, personally, use most
often), you could try modifying the name of a project that you edit so
it is different than the original. Then you can have the original also
checked out in your workspace and open/close it as needed.
Hope this helps,
Eric
Re: Best practice: Working on Eclipse CVS stuff [message #335715 is a reply to message #335684] Thu, 23 April 2009 05:43 Go to previous message
Hy Eric, hy Walter.
Thanks for the insight in how you manage that task.
Another option (the one I use now) is to have another VCS on top of the
local CVS repository (so one repo managed by two VCSs). I use Mercurial
for that task. Now I can switch between the original version and my
version very fast.
This has also the advantage that I can make bigger changes and can
always roll back to intermediate changes that I committed to Mercurial.
But at the same time can fetch new updates from the Eclipse CVS.
Kai
Previous Topic:dynamic ruler column
Next Topic:Query on platform UI editors
Current Time: Tue Jul 22 15:44:09 EDT 2025
Powered by FUDForum. Page generated in 0.25171 seconds
