Home » Eclipse Projects » Eclipse Platform » using fragments for version-specific features
using fragments for version-specific features [message #335653] Sun, 19 April 2009 13:16 Go to next message
Originally posted by: marc.esher.comcast.net
All,
I'd like to take advantage of the new JFace StyledCellLabelProvider in my
plugin; however, I have a lot of users still on 3.3
Is there a way that I can add this support for my 3.4+ users without
creating an entirely separate branch of the plugin just for a single
LabelProvider class? I imagine this is a fairly common thing, but I didn't
see any info on this in my Eclipse books. Possibly though I just don't know
the terminology to look for
Thanks for any tips
marc
Re: using fragments for version-specific features [message #335665 is a reply to message #335653] Mon, 20 April 2009 10:46 Go to previous message
Marc E wrote:
> All,
> my plugin; however, I have a lot of users still on 3.3
> didn't see any info on this in my Eclipse books. Possibly though I just
> don't know the terminology to look for
you can either create a 3.4.x compatible version of your plugin that
requires the JFace 3.4.x (so that your 3.3 compatible plugin will be
loaded if 3.4 is not available). Since you are consuming new API, this
the the way to do it.
But I don't see why a fragment wouldn't work ... if you host your
fragment and depend on 3.4 jface. A possible problem is that since a
fragment is simply absorbed into the host plugin space, your fragment
can't require 3.4 JFace if the host can already see 3.3 (at least, you
might have to add that restriction manually).
PW
Paul Webster
Previous Topic:Contributing drop down actions to a view
Next Topic:Properties Page behavior
Current Time: Wed Dec 03 13:25:18 EST 2025
Powered by FUDForum. Page generated in 0.35046 seconds
