Home » Eclipse Projects » Eclipse Platform » debugging menu contributions
debugging menu contributions [message #335652] Sun, 19 April 2009 10:54 Go to next message
Originally posted by: marc.esher.comcast.net
All,
I've got a plugin trying to contribute ecf docshare to the popup menu of a
specific editor. I *think* I have the contextID of the editor correct, but I
can't be sure b/c it's not specified in the plugin.xml anywhere. it's a
commercial editor.
Here's what I have in my plugin xml:
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:#com.adobe.flexbuilder.editors.mxml.MXMLCodeContext ">
<dynamic
class=" org.eclipse.ecf.internal.provisional.docshare.menu.DocShareR osterMenuContributionItem "
id="org.miz.mxmldocsharecontribution">
</dynamic>
</menuContribution>
</extension>
And I have all (I think) the required dependencies set up correctly in the
manifest. Still, the menu never gets added.
I'm wondering: is there a way to debug when something isn't added to the
popup menu? Or, is there a way to definitively get the proper popup
locationURI for any editor? I'm fairly certain that the menu is not being
contributed because when I set a breakpoint in the
DocShareRosterMenuContributionItem, it never trips. It does catch on other
editors where DocShare is working successfully, however.
Any help learning how to debug the guts of this thing is most appreciated.
marc
Re: debugging menu contributions [message #335663 is a reply to message #335652] Mon, 20 April 2009 10:39 Go to previous messageGo to next message
If you use ALT+SHIFT+F1 in the editor it will give you a list of active
menu contribution identifiers. This is the list that you can contribute
to use popup:
PW
Paul Webster
Re: debugging menu contributions [message #335776 is a reply to message #335652] Wed, 29 April 2009 08:24 Go to previous messageGo to next message
Hi marc
To debug this kind of problems I've developed an eclipse rcp inspection
plugin called yari (yet another rcp inspector). You will find it on
sourceforge (http://yari.wiki.sourceforge.net/).
To find the identifier:
Open the view YARI->Eclipse Inspector. Inspect the current editor by
pushing the smiley and click on the editor part.
In the tree navigation of the Eclipse Inspector view open "Workbench" ->
"Part's Site". The property "contextMenuIDs" holds the correct menu
contribution identifiers. Double click on it to see all elements.
hth,
remo
Marc E wrote:
> All,
> of a specific editor. I *think* I have the contextID of the editor
> correct, but I can't be sure b/c it's not specified in the plugin.xml
> anywhere. it's a commercial editor.
> <menuContribution
> <dynamic
> </dynamic>
> </menuContribution>
> </extension>
> the manifest. Still, the menu never gets added.
> being contributed because when I set a breakpoint in the
> other editors where DocShare is working successfully, however.
> marc
Re: debugging menu contributions [message #335828 is a reply to message #335776] Sat, 02 May 2009 14:46 Go to previous message
Thanks for the help guys. It's quite valuable.
Marc
"Remo Loetscher" <remo.loetscher@postfinance.ch> wrote in message
news:49f846e1$1@news.post.ch...
> Hi marc
> hth,
> remo
> Marc E wrote:
>> All,
>> a specific editor. I *think* I have the contextID of the editor correct,
>> but I can't be sure b/c it's not specified in the plugin.xml anywhere.
>> <menuContribution
>> <dynamic
>> </dynamic>
>> </menuContribution>
>> </extension>
>> appreciated.
>> marc
Previous Topic:"Build site" debugging
Next Topic:Set focus in properties view
Current Time: Thu Nov 27 20:43:48 EST 2025
Powered by FUDForum. Page generated in 0.04358 seconds
