Home » Eclipse Projects » Eclipse Platform » Assign ".a.b" extention to my editor?
Assign ".a.b" extention to my editor? [message #335538] Tue, 14 April 2009 04:20 Go to next message
--------------080902000204070301020906
Content-Type: text/plain; charset=UTF-8; format=flowed
For some reason, my client wants to make the *.ui.xml files to open with
a custom editor. But I found that it's no use to config it in the
org.eclipse.ui.editors extention.
I noticed the bug22905's status is still "new". Is there some other way
to achieve what I want?
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=22905>
*/Dollyn/*
Content-Type: text/html; charset=UTF-8
<html>
<head>
</head>
with a custom editor. But I found that it's no use to config it in the
org.eclipse.ui.editors extention.<br>
<br>
to achieve what I want?<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=22905"></a>
<div class="moz-signature">-- <br>
<meta http-equiv="Content-Language" content="zh-cn">
<meta http-equiv="Content-Type" content="text/html; ">
<title>Dollyn</title>
<p><b><i><font color="#0000ff" face="Courier New">Dollyn</font></i></b></p>
</div>
</body>
</html>
--------------080902000204070301020906--
Re: Assign ".a.b" extention to my editor? [message #335542 is a reply to message #335538] Tue, 14 April 2009 05:45 Go to previous messageGo to next message
> way to achieve what I want?
You could define a new content type and hook up your editor to it.
Dani
> */Dollyn/*
Re: Assign ".a.b" extention to my editor? [message #335561 is a reply to message #335542] Tue, 14 April 2009 21:35 Go to previous messageGo to next message
--------------000401090705040009020407
Content-Type: text/plain; charset=gb18030; format=flowed
But how? A content type can only define file-extensions and file-names,
but it seems no use to give it "double-extension"(like filenames xx.a.b).
>> the org.eclipse.ui.editors extention.
> Dani
>> */Dollyn/*
*/Dollyn/*
Content-Type: text/html; charset=gb18030
<html>
<head>
<meta content="text/html;charset=gb18030" http-equiv="Content-Type">
<title></title>
</head>
xx.a.b). <br>
<br>
<blockquote cite="mid:gs1lvc$r7v$1@build.eclipse.org" type="cite">Dollyn
wrote:
<br>
<blockquote type="cite">For some reason, my client wants to make the
*.ui.xml files to open with a custom editor. But I found that it's no
use to config it in the org.eclipse.ui.editors extention.
<br>
<br>
<br>
</blockquote>
<br>
<br>
Dani
<br>
<blockquote type="cite">--
Re: Assign ".a.b" extention to my editor? [message #335562 is a reply to message #335561] Wed, 15 April 2009 01:57 Go to previous messageGo to next message
> file-names, but it seems no use to give it "double-extension"(like
> filenames xx.a.b).
Read the extension point doc again with focus on content describer.
Dani
>> Dani
>>> */Dollyn/*
> */Dollyn/*
Re: Assign ".a.b" extention to my editor? [message #335615 is a reply to message #335562] Thu, 16 April 2009 09:10 Go to previous messageGo to next message
The describer can only get the inputstream, but my files are the same
with normal xml-files, except the file-name.
Daniel Megert 写道:
>> filenames xx.a.b).
> Dani
>>> Dani
>>>> */Dollyn/*
>> */Dollyn/*
Re: Assign ".a.b" extention to my editor? [message #335619 is a reply to message #335615] Thu, 16 April 2009 11:44 Go to previous messageGo to next message
The API is:
org.eclipse.core.runtime.content.IContentDescriber.describe( InputStream,
IContentDescription)
and it allows to set properties on the content description, doesn't it?
Dani
> but my files are the same with normal xml-files, except the file-name.
> Daniel Megert 写道:
>>> filenames xx.a.b).
>> Dani
>>>>> open with a custom editor. But I found that it's no use to config
>>>>> other way to achieve what I want?
>>>> Dani
>>>>> */Dollyn/*
>>> */Dollyn/*
Re: Assign ".a.b" extention to my editor? [message #335630 is a reply to message #335619] Thu, 16 April 2009 23:36 Go to previous messageGo to next message
Re: Assign ".a.b" extention to my editor? [message #335632 is a reply to message #335630] Fri, 17 April 2009 01:18 Go to previous messageGo to next message
>What I want is: all and only the files that have the name like *.a.b will
>be opened with my editor. Is that possible?
AFAIK, that is not possible. However, as Dani said, you can use the
contentTypes extension point. Since your files are XML, you can set the
content type with the root element of your XML:
<extension
point="org.eclipse.core.contenttype.contentTypes">
<content-type
id="yourXmlTypeId"
name="Some Name"
priority="normal">
<describer
class=" org.eclipse.core.runtime.content.XMLRootElementContentDescri ber ">
<parameter
name="element"
value="your_root_element">
</parameter>
</describer>
</content-type>
</extension>
Now you can associate this content type with your editor. HTH
- Prakash
http://blog.eclipse-tips.com
Re: Assign ".a.b" extention to my editor? [message #335634 is a reply to message #335632] Fri, 17 April 2009 01:53 Go to previous message
--------------030700010009020609020407
Well, this seems not what I want...
Our XML's have nothing in common, no common root's, no common schema...
But thank you all the same. Maybe we can persuade our clients to create
a common schema
for the XML...
> <extension
> <content-type
> id="yourXmlTypeId"
> name="Some Name"
> priority="normal">
> <describer
> <parameter
> name="element"
> </parameter>
> </describer>
> </content-type>
> </extension>
> - Prakash
*/Dollyn/*
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
<title></title>
</head>
Well, this seems not what I want...<br>
<br>
Our XML's have nothing in common, no common root's, no common schema...<br>
<br>
a common schema<br>
for the XML...<br>
<br>
Prakash G.R. wrote:
<blockquote cite="mid:gs93fi$es6$1@build.eclipse.org" type="cite">
<pre wrap="">What I want is: all and only the files that have the name like *.a.b will
</pre>
</blockquote>
<pre wrap=""><!---->
&lt;extension
point="org.eclipse.core.contenttype.contentTypes"&gt;
&lt;content-type
id="yourXmlTypeId"
name="Some Name"
priority="normal"&gt;
&lt;describer
class=" org.eclipse.core.runtime.content.XMLRootElementContentDescri ber "&gt;
&lt;parameter
name="element"
value="your_root_element"&gt;
&lt;/parameter&gt;
&lt;/describer&gt;
&lt;/content-type&gt;
&lt;/extension&gt;
- Prakash
</pre>
</blockquote>
<br>
</div>
</body>
</html>
--------------030700010009020609020407--
Previous Topic:Preferences: bugs and REF's for 3.4.2?
Next Topic:Re: Don't succeed to fetch bundles with p2IU, nor to use p2 director
Current Time: Fri Nov 14 16:54:12 EST 2025
Powered by FUDForum. Page generated in 0.05031 seconds
