Home » Eclipse Projects » Eclipse Platform » manual eclipse update failed
manual eclipse update failed [message #335486] Fri, 10 April 2009 08:00 Go to next message
Originally posted by: juergen.scheffler.gmx.de
i tried to manually install a SDK:
http://www.eclipse.org/modeling/emft/downloads/?project=ecor etools
the ecore.emft .
So I
1. closed eclipse
2. unpacked the zip
3. copied the features and plugin folder to my eclipse ganymed folder
4. started eclipse -> no emft was installed
5. started eclipse.exe -clean -> no emft was installed
Whats my line?
G
Juergen
Re: manual eclipse update failed [message #335487 is a reply to message #335486] Fri, 10 April 2009 08:26 Go to previous messageGo to next message
Jürgen,
Likely you have things missing like EMF or GMF. Try deleting
<workspace>/.metadata/.log, or clearing the Error Log view. Then
shutdown again, and use "-clean -debug" for the arguments. The -debug
flag should help produce more verbose messages as to why various plugins
fail to be enabled.
Jürgen Scheffler wrote:
> the ecore.emft .
> So I
> 1. closed eclipse
> 2. unpacked the zip
> Whats my line?
> G
> Juergen
Re: manual eclipse update failed [message #335489 is a reply to message #335487] Fri, 10 April 2009 08:48 Go to previous messageGo to next message
Yes I can ....not solved this issue:
!SESSION 2009-04-10 14:45:04.796
eclipse.buildId=M20080911-1700
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -debug
!ENTRY org.eclipse.equinox.p2.director 2 0 2009-04-10 14:45:10.328
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-04-10 14:45:10.328
!MESSAGE Unable to satisfy dependency from
org.eclipse.emf.ecoretools.diagram.ui.outline 0.8.0.v200806130600 to
requiredCapability: osgi.bundle/org.eclipse.gmf.runtime.notation/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.gmf.runtime.diagram.ui/0.0.0.
org.eclipse.emf.ecoretools.diagram 0.8.0.v200806130600 to
requiredCapability: osgi.bundle/org.eclipse.gmf.runtime.emf.core/0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.emf.commands.core/0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.emf.ui.properties/0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.properties/0. 0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.providers/0.0 .0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.providers.ide /0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.render/0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.resources.edi tor/0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.resources.edi tor.ide/0.0.0.
requiredCapability: osgi.bundle/org.eclipse.gmf.runtime.draw2d.ui/0.0.0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.printing/0.0. 0.
requiredCapability:
osgi.bundle/org.eclipse.gmf.runtime.diagram.ui.printing.rend er/0.0.0.
org.eclipse.emf.ecoretools.filters 0.8.0.v200806130600 to
requiredCapability:
org.eclipse.emf.ecoretools.feature.group 0.8.0.v200806130600 to
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.ocl.feature.group/ [1.1.100,2.0.0).
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.gmf.feature.group/[1.1 .0,2.0.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.emf.ocl
1.1.101.v200808291106 to requiredCapability:
java.package/lpg.lpgjavaruntime/[1.0.0,1.2.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.ocl
1.2.3.v200901071407 to requiredCapability:
osgi.bundle/net.sourceforge.lpg.lpgjavaruntime/0.0.0.
!MESSAGE Unable to satisfy dependency from org.eclipse.ocl.uml
osgi.bundle/org.eclipse.uml2.uml/[2.2.0,2.3.0).
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-04-10 14:45:10.500
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-04-10 14:45:10.500
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
requiredCapability:
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-04-10 14:45:10.515
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-04-10 14:45:10.515
!MESSAGE No solution found because the problem in
G:\DOKUME~1\js2002\LOKALE~1\Temp\p2Encoding45714721982849388 58.opb is
unsatisfiable.
!ENTRY org.eclipse.equinox.p2.director 4 1 2009-04-10 14:45:11.125
!MESSAGE Cannot complete the install because some dependencies are not
satisfiable
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-04-10 14:45:11.125
!MESSAGE Unsatisfied dependency:
requiredCapability: osgi.bundle/net.sourceforge.lpg.lpgjavaruntime/0.0.0
!MESSAGE Unsatisfied dependency: requiredCapability:
osgi.bundle/org.eclipse.ocl/[1.2.0,2.0.0)
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.validation.ocl/
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.ocl/[1.0.0,2.0.0)
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.ocl/[1.1.0,2.0.0)
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.ocl.ecore/[1.1.0,2.0.0 )
org.eclipse.equinox.p2.iu/org.eclipse.emf.search.ocl.feature .group/
org.eclipse.equinox.p2.iu/org.eclipse.emf.search.ecore.ocl.f eature.group/
osgi.bundle/org.eclipse.emf.ocl/[1.1.0,2.0.0)
requiredCapability:
requiredCapability:
osgi.bundle/org.eclipse.ocl.ecore/[1.1.0,2.0.0)
osgi.bundle/org.eclipse.emf.ocl/[1.0.0,2.0.0)
osgi.bundle/org.eclipse.ocl/[1.1.0,2.0.0)
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.search.ocl/0.0.0
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.search.ecore.ocl.u i/
requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.ocl.uml/0.0.0
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.query.ocl/0.0.0
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.search.ecore.ocl/
requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.ocl.ecore/0.0.0
requiredCapability: org.eclipse.equinox.p2.iu/org.eclipse.ocl/0.0.0
requiredCapability:
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.search.ocl.ui/0.0. 0
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.ocl/[1.2.0,2.0.0)
requiredCapability:
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.ocl/[1.1.0,2.0.0)
requiredCapability:
requiredCapability:
osgi.bundle/org.eclipse.ocl.ecore/0.0.0
!MESSAGE Unsatisfied dependency: requiredCapability: osgi.bundle/org.eclipse.ocl/0.0.0
osgi.bundle/org.eclipse.emf.query.ocl/0.0.0
osgi.bundle/org.eclipse.emf.search.ocl/0.0.0
osgi.bundle/org.eclipse.ocl.uml/0.0.0
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.query.ocl.feature. group/
requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.validation.ocl.fea ture.group/
osgi.bundle/org.eclipse.emf.search.ecore.ocl/0.0.0
osgi.bundle/org.eclipse.emf.search.ocl.ui/0.0.0
!ENTRY org.eclipse.osgi 2 0 2009-04-10 14:45:11.140
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-04-10 14:45:11.140
!MESSAGE Bundle
reference:file:plugins\org.eclipse.ocl_1.2.3.v200901071407.j ar was not
resolved.
!SUBENTRY 2 org.eclipse.ocl 2 0 2009-04-10 14:45:11.140
!MESSAGE Missing required bundle net.sourceforge.lpg.lpgjavaruntime_0.0.0.
!MESSAGE Bundle
reference:file:plugins\org.eclipse.ocl.uml_1.2.3.v2009010714 07.jar was
not resolved.
!SUBENTRY 2 org.eclipse.ocl.uml 2 0 2009-04-10 14:45:11.140
!MESSAGE Missing required bundle org.eclipse.uml2.uml_[2.2.0,2.3.0).
!MESSAGE Bundle
reference:file:plugins\org.eclipse.emf.ocl_1.1.101.v20080829 1106.jar was
not resolved.
!SUBENTRY 2 org.eclipse.emf.ocl 2 0 2009-04-10 14:45:11.140
!MESSAGE Missing imported package lpg.lpgjavaruntime_[1.0.0,1.2.0).
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle
was not resolved.
!MESSAGE Missing required bundle org.eclipse.ocl_[1.2.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.ocl.ecore_[1.1.0,2.0.0).
!MESSAGE Bundle
reference:file:plugins\org.eclipse.emf.query.ocl_1.2.0.v2008 05130238.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.query.ocl 2 0 2009-04-10 14:45:11.140
!MESSAGE Missing required bundle org.eclipse.emf.ocl_[1.1.0,2.0.0).
!MESSAGE Bundle
reference:file:plugins\org.eclipse.emf.search.ecore.ocl_0.7. 0.v200806130939.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.search.ecore.ocl 2 0 2009-04-10 14:45:11.140
!MESSAGE Missing required bundle org.eclipse.emf.query.ocl_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ocl.ecore_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.search.ocl_0.0.0.
!MESSAGE Bundle
reference:file:plugins\org.eclipse.emf.search.ecore.ocl.ui_0 .7.0.v200806130939.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.search.ecore.ocl.ui 2 0 2009-04-10 14:45:11.140
!MESSAGE Missing required bundle org.eclipse.emf.search.ecore.ocl_0.0.0.
!MESSAGE Missing required bundle org.eclipse.emf.search.ocl.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ocl_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ocl.uml_0.0.0.
!MESSAGE Bundle
reference:file:plugins\org.eclipse.emf.search.ocl_0.7.0.v200 806130939.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.search.ocl 2 0 2009-04-10 14:45:11.140
!MESSAGE Bundle
reference:file:plugins\org.eclipse.emf.search.ocl.ui_0.7.0.v 200806130939.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.search.ocl.ui 2 0 2009-04-10 14:45:11.140
!MESSAGE Bundle
reference:file:plugins\org.eclipse.emf.validation.ocl_1.2.0. v200805130238.jar
was not resolved.
!SUBENTRY 2 org.eclipse.emf.validation.ocl 2 0 2009-04-10 14:45:11.140
!MESSAGE Missing required bundle org.eclipse.emf.ocl_[1.0.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.ocl_[1.1.0,2.0.0).
!MESSAGE Bundle
not resolved.
!MESSAGE Bundle
reference:file:plugins\org.eclipse.ocl.ecore_1.2.1.v20080730 1850.jar
was not resolved.
!SUBENTRY 2 org.eclipse.ocl.ecore 2 0 2009-04-10 14:45:11.140
!MESSAGE Bundle
reference:file:plugins\org.eclipse.ocl.uml_1.2.3.v2009010714 07.jar [297]
was not resolved.
!ENTRY org.eclipse.jface 2 0 2009-04-10 14:45:16.578
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2009-04-10 14:45:16.578
!MESSAGE A conflict occurred for CTRL+SHIFT+P:
Binding(CTRL+SHIFT+P,
ParameterizedCommand(Command(org.eclipse.ecf.presence.ui.com mands.browse,Open
Contact,
Category(org.eclipse.ecf.ui.commands.category,Communications ,null,true),
org.eclipse.ecf.internal.presence.ui.handlers.BrowseHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.emf.search.ecore.co mmon.ui.OpenFilteredEPackageMetaElementsSelectionDialogComma nd,Open
Filtered Ecore Package Meta-Elements Dialog,
Open Filtered Ecore Package Meta-Elements Dialog,
Category(org.eclipse.modeling.editors,Modeling Editors,Modeling
Editors Commands,true),
org.eclipse.emf.search.ecore.common.ui.handlers.OpenFiltered EPackageMetaElementSelectionDialogHandler,
,,true),null),
Re: manual eclipse update failed [message #335492 is a reply to message #335489] Fri, 10 April 2009 09:38 Go to previous messageGo to next message
Jürgen,
I get the sense that OCL hasn't been installed. The fastest solution
here would be to install the modeling package. It's got all the right
versions of this modeling stuff.
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> unsatisfiable.
> satisfiable
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> root constraints are not resolved:
> !MESSAGE Bundle
> resolved.
> !MESSAGE Bundle
> not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> 14:45:11.140
> 14:45:11.140
> 14:45:11.140
> 14:45:11.140
> 14:45:11.140
> 14:45:11.140
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> was not resolved.
> !MESSAGE Bundle
> [297] was not resolved.
> normal accelerator operation.
> Contact,
> ,,true),null),
> Editors,Modeling Editors Commands,true),
> ,,true),null),
Re: manual eclipse update failed [message #335496 is a reply to message #335492] Fri, 10 April 2009 10:26 Go to previous messageGo to next message
org.e.modeling ?! or which? (cant look right now, because of mirror lag)
Re: manual eclipse update failed [message #335498 is a reply to message #335496] Fri, 10 April 2009 10:33 Go to previous messageGo to next message
--------------000503090803060504060307
J
Re: manual eclipse update failed [message #335504 is a reply to message #335498] Fri, 10 April 2009 12:27 Go to previous messageGo to next message
Thx! is there a chanceto get all settings (javadoc linkage, code colors
etc) from my "old eclipse IDE" ?
Ed Merks schrieb:
> Jürgen,
> This one:
> < http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/ganymede/SR2/eclipse-modeling-ganym ede-SR2-incubation-win32.zip>
Re: manual eclipse update failed [message #335505 is a reply to message #335504] Fri, 10 April 2009 12:40 Go to previous messageGo to next message
Jürgen,
You can use File->Export->General->Preferences and then import them
elsewhere. What I always do though is open the file in a text editor
and delete any setting that contains an absolute location of the old
workspace or installation...
> colors etc) from my "old eclipse IDE" ?
> Ed Merks schrieb:
>> Jürgen,
>> This one:
>>> lag)
Re: manual eclipse update failed [SOLVED] [message #335507 is a reply to message #335505] Fri, 10 April 2009 14:16 Go to previous message
thx 4 answering silly things and fast as hell!
Previous Topic:can't debug into source attachment
Next Topic:Problems with WorkspaceModifyOperation and IProgressService.run(...)
Current Time: Mon Nov 10 19:52:31 EST 2025
Powered by FUDForum. Page generated in 0.05741 seconds
