Home » Eclipse Projects » Eclipse Platform » eclipse 3.4.2 on Solaris 9
eclipse 3.4.2 on Solaris 9 [message #335472] Thu, 09 April 2009 18:36 Go to next message
Is it possible to run eclipse 3.4.2 on Solaris 9?
What are the minimum requirements?
I installed the gtk+ 2.12 package from sunfreeware, along with its
dependencies, but still no luck.
eclipse 3.4.2 trouble on Solaris 9/10 [message #335500 is a reply to message #335472] Fri, 10 April 2009 11:07 Go to previous messageGo to next message
well, I tried on Solaris 10 and getting the same trouble. The application
crashes with a core dump. I also tried with a sample application with the
same result.
On that machine, I can run gtk-demo without problem. I also double check
the java version used to launch the app and it higher than the minimum
requirement listed in the 3.4.2 readme
( http://www.eclipse.org/eclipse/development/readme_eclipse_3. 4.2.html#TargetOperatingEnvironments)
What else do I need to check?
Re: eclipse 3.4.2 trouble on Solaris 9/10 [message #335528 is a reply to message #335500] Mon, 13 April 2009 09:52 Go to previous message
I guess I will be opening a bug then...
Previous Topic:Eclipse Update Manager and cookie based authentication over HTTPS
Next Topic:Setting GlobalActionHandler for command
Current Time: Thu Nov 06 16:37:35 EST 2025
Powered by FUDForum. Page generated in 0.03433 seconds
