Home » Eclipse Projects » Eclipse Platform » can't debug into source attachment
can't debug into source attachment [message #335471] Thu, 09 April 2009 17:01 Go to next message
I want to use the debugger to step into the source attachment of a .jar
which is on my Java Build Path. I can view the code with F3 (jump to
declaration) but can't step into it in the debugger. When I try to step
into that method I get "Source not found" and a button to "Edit Source
Lookup Path". I clicked the button and added xyz.src.jar as an Archive,
but to no avail.
I've seen a lot of other posts on this topic but none have helped me so
far. Hope someone knows how to do this!
Re: can't debug into source attachment [message #335474 is a reply to message #335471] Thu, 09 April 2009 20:35 Go to previous messageGo to next message
> but to no avail.
Make sure that the classes in the jar file have been compiled with debug
enabled.
Re: can't debug into source attachment [message #335494 is a reply to message #335474] Fri, 10 April 2009 10:11 Go to previous message
>> but to no avail.
> enabled.
Thank you very much! I cleaned away the old class files on disk and in my
ant build script for the .jar I added debug="on" to the <javac> target.
Now I can debug it.
Previous Topic:WebstartMain with OpenJDK on Linux
Next Topic:manual eclipse update failed
Current Time: Sun Nov 09 03:52:39 EST 2025
Powered by FUDForum. Page generated in 0.29551 seconds
