Home » Eclipse Projects » Eclipse Platform » nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6
nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6 [message #335423] Tue, 07 April 2009 13:28 Go to next message
Originally posted by: chlache.talita.org
I am working on an Mozilla Html Editor.
On Eclipse 3.4.1 (nsIWebBrowser)browser.getWebBrowser() works with no problems.
After moving to 3.5M6 (nsIWebBrowser)browser.getWebBrowser() always returns null, even though
the Mozilla Browser has completely loaded.
The Error seems to occcur when SWT.Browser calls ClassForName("org.mozilla.xpcom"), which returns null.
When I run the same Code as a Snippet in 3.5M6 (as in Snippet267) the call works fine though.
Is this a Bug? Thanks for any help.
Andreas
Re: nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6 [message #335424 is a reply to message #335423] Tue, 07 April 2009 15:36 Go to previous messageGo to next message
> problems.
> Andreas
As a test i put some of the SWT.Mozilla initialization code in my plugin:
try {
Class clazz = Class.forName ("org.mozilla.xpcom.Mozilla"); //$NON-NLS-1$
Method method = clazz.getMethod ("getInstance", new Class[0]); //$NON-NLS-1$
Object mozilla = method.invoke (null, new Object[0]);
method = clazz.getMethod ("getComponentManager", new Class[0]); //$NON-NLS-1$
try {
method.invoke (mozilla, new Object[0]);
} catch (InvocationTargetException e) {
} catch (ClassNotFoundException e) {
/* JavaXPCOM is not on the classpath */
} catch (NoSuchMethodException e) {
/* the JavaXPCOM on the classpath does not implement initialize() */
} catch (IllegalArgumentException e) {
} catch (IllegalAccessException e) {
and it works perfectly, only to immediately fail when calling
browser = new Browser(parent, SWT.MOZILLA | SWT.BORDER);
in the SWT plugin. Class.forName returning NULL.
How is that possible?
Re: nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6 [message #335436 is a reply to message #335424] Wed, 08 April 2009 08:00 Go to previous messageGo to next message
org.eclipse.swt.browser.Mozilla can't load org.mozilla.xpcom.Mozilla
because "DynamicImport-Package: org.mozilla.xpcom" is missing in the
MANIFEST.MF file.
There isn't a problem when using SWT out of OSGi (Snippet267, for instance).
The problem is fixed in the Eclipse trunk.
Snjeza
>> problems.
>> Andreas
> try {
> //$NON-NLS-1$
> try {
> initialize() */
Re: nsIWebBrowser webBrowser = (nsIWebBrowser)browser.getWebBrowser() NULL on 3.5M6 [message #335437 is a reply to message #335436] Wed, 08 April 2009 08:20 Go to previous message
> MANIFEST.MF file.
> instance).
> Snjeza
Thanks a lot for this information. I owe you one.
I will update and I hope that it will work.
Andreas
Previous Topic:Paint error for toolbars with temporary invisible commands
Next Topic:Quick Fix Handler enabled when there are not resolutions
Current Time: Tue Jul 22 15:48:04 EDT 2025
Powered by FUDForum. Page generated in 0.04200 seconds
