Home » Eclipse Projects » Eclipse Platform » Showing Views Shortlist?
Showing Views Shortlist? [message #335396] Mon, 06 April 2009 09:05 Go to next message
I want to show the view shortlist and the perspective short list using
'org.eclipse.ui.menus'.
I allready found to open preferences using a command with id
'org.eclipse.ui.window.preferences'.
Unfortunately I can'nt finde the id's for the apropiate commands for
opening the views shortlist and the preferences shortlist.
Is there a documentation showing all available ID's`?
Thanks!
Re: Showing Views Shortlist? [message #335401 is a reply to message #335396] Mon, 06 April 2009 10:03 Go to previous messageGo to next message
I don't think those 2 are supported yet. I would check
org.eclipse.ui.internal.ide.WorkbenchActionBuilder ... if it is done via
a command there, then it has been converted to commands. If it is still
done with the ContributionItemFactory, then it is probably not available
via commands/menu contributions yet.
PW
Paul Webster
Re: Showing Views Shortlist? [message #335403 is a reply to message #335401] Mon, 06 April 2009 10:15 Go to previous message
Meanwhile I found out hat perspectives shortlist can be opened using the
command 'org.eclipse.ui.perspectives.showPerspective'.
Previous Topic:KeyBindings not shown properly in popup
Next Topic:externalized strings : conver to 'eclipse mechanism'
Current Time: Fri Jul 18 02:08:25 EDT 2025
Powered by FUDForum. Page generated in 0.08093 seconds
