Home » Eclipse Projects » Eclipse Platform » Time format in local history
Time format in local history [message #335375] Sat, 04 April 2009 08:22 Go to next message
unfortunately the time format of the recent file changes are indicated in
the local history view of Eclipse 3.4.2 in a time format using AM and PM.
Is it possible to change/configure this time format of the local history, e.
g. to the ISO 8601 time format HH:mm (e. g. 14:00 instead of 02:00 pm); if
yes, how/where?
Thomas Wiedmann
Re: Time format in local history [message #335389 is a reply to message #335375] Mon, 06 April 2009 05:03 Go to previous messageGo to next message
Thomas Wiedmann wrote:
> Hello,
> in the local history view of Eclipse 3.4.2 in a time format using AM
> and PM.
Which view/dialog exactly? The ones I know use the OS time format (and
that's where you can change it).
Dani
> history, e. g. to the ISO 8601 time format HH:mm (e. g. 14:00 instead
> of 02:00 pm); if yes, how/where?
> Thomas Wiedmann
Re: Time format in local history [message #335450 is a reply to message #335389] Wed, 08 April 2009 17:01 Go to previous messageGo to next message
Its the local history view (Team/History) - as described.
> The ones I know use the OS time format (and that's where you can change
> it).
Definitely no - I use a German Windows XP and there the time formats are
different, i. e. without am and pm.
Thomas Wiedmann
Re: Time format in local history [message #335454 is a reply to message #335450] Thu, 09 April 2009 03:25 Go to previous messageGo to next message
>> change it).
> are different, i. e. without am and pm.
Don't say "definitely no". If you know how it works why do you need to
ask here? ;-)
The time in the History view is correct (same as in OS) on my machine.
Maybe you pass a different language/local/timezone when starting Eclipse
or you use -nl <something>.
Anyway, if your machine is correctly setup and you don't change the
command line arguments then the time should be like in your OS. If not,
please file a bug report.
Dani
> Thomas Wiedmann
Re: Time format in local history [message #335455 is a reply to message #335454] Thu, 09 April 2009 06:03 Go to previous messageGo to next message
>>> change it).
> ask here? ;-)
there is already one:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139599
Re: Time format in local history [message #335456 is a reply to message #335455] Thu, 09 April 2009 06:18 Go to previous messageGo to next message
>>>> change it).
>> ask here? ;-)
>> Eclipse or you use -nl <something>.
>> not, please file a bug report.
also
https://bugs.eclipse.org/bugs/show_bug.cgi?id=127452
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134475
Re: Time format in local history [message #335522 is a reply to message #335454] Mon, 13 April 2009 05:56 Go to previous message
Correct - I start Eclipse with EN -nl option. The reason is that the English
version is standard and international; most documentations and FAQ's are in
English, so it's easier to find some subjects.
Nevertheless it would be advantageous to enable configuring/adapting the
datetime format settings.
Thomas Wiedmann
Previous Topic:eclipse.org/examples vs. platform examples
Next Topic:Eclipse Update Manager and cookie based authentication over HTTPS
Current Time: Wed Nov 05 06:49:16 EST 2025
Powered by FUDForum. Page generated in 0.08974 seconds
