Home » Eclipse Projects » Eclipse Platform » Re: Re-open file in existing editor
Re: Re-open file in existing editor [message #335358] Fri, 03 April 2009 12:36 Go to next message
Rucha wrote:
> Hello,
> I am using :
> IDE.openEditor(PlatformUI.getWorkbench().getActiveWorkbenchW indow().getActivePage(),
> editor, "id") ;
> to refresh a changed file, since thats the easiest way to do it in case
> of my editor. However, the problem is that it opens the file in a new
> tab, which then ends up in a different order. Is there a way to :
> - re-open the same file in an existing editor instance, so that it is
> effectively recreated ? - or remember the original tab order, and order
> them after re-opening the file ?
> any guidance will be greatly appreciated.
> thanks, rucha.
More appropriate for eclipse.platform, re-routing.
PW
Paul Webster
Re: Re-open file in existing editor [message #335359 is a reply to message #335358] Fri, 03 April 2009 12:43 Go to previous message
Paul Webster wrote:
> Rucha wrote:
>> Hello,
>> I am using :
>> editor, "id") ;
Why aren't you listening for an
org.eclipse.core.resources.IResourceChangeEvent and then updating your
file? That's how resource based editors work.
The resource change event will let you know when it's time to refresh
your contents.
PW
Paul Webster
Previous Topic:Problem updating Ganymede
Next Topic:Custom Event
Current Time: Mon Nov 17 04:37:33 EST 2025
Powered by FUDForum. Page generated in 0.39355 seconds
