| Re: Re-open file in existing editor [message #335358] |
Fri, 03 April 2009 12:36  |
Rucha wrote:
> Hello,
> I am using :
> IDE.openEditor(PlatformUI.getWorkbench().getActiveWorkbenchW indow().getActivePage(),
> editor, "id") ;
> to refresh a changed file, since thats the easiest way to do it in case
> of my editor. However, the problem is that it opens the file in a new
> tab, which then ends up in a different order. Is there a way to :
> - re-open the same file in an existing editor instance, so that it is
> effectively recreated ? - or remember the original tab order, and order
> them after re-opening the file ?
> any guidance will be greatly appreciated.
> thanks, rucha.
More appropriate for eclipse.platform, re-routing.
PW
Paul Webster
FUDForum. Page generated in 0.03539 seconds
