Home » Eclipse Projects » Eclipse Platform » How to close Jface wizard while progress bar is running for a long time
How to close Jface wizard while progress bar is running for a long time [message #335336] Thu, 02 April 2009 10:14 Go to next message
How to close the Jface wizard while progress bar is running doing a job
for a longer time.Since fewer times call to database is taking time i want
to close the Jface wizard but i am getting the following message
"wizard can not be closed due to an active operation. you must cancel the
operation before you can close the wizard".
How to cancel the operation from the UI.
NAAG
Re: How to close Jface wizard while progress bar is running for a long time [message #335346 is a reply to message #335336] Thu, 02 April 2009 23:54 Go to previous messageGo to next message
When you are running the operation thru the getContainer().run(...), you
should set the cancellable parameter to true. That would enable the Cancel
button
- Prakash
http://blog.eclipse-tips.com
Re: How to close Jface wizard while progress bar is running for a long time [message #335347 is a reply to message #335346] Fri, 03 April 2009 05:11 Go to previous messageGo to next message
Hi prakash
I have set the cancelled flag as true. I couldnt see any cancel image
enabled next to progressbar.
I am using a long run operation in wizard page. getContainer().run method
//Sample code
getContainer().run(true, true, new IRunnableWithProgress() {
public void run(IProgressMonitor monitor) throws
InvocationTargetException, InterruptedException {
monitor.begintask("");
//SDK and DB calls to fill the data to UI
monitor.done();
what should i do now? please help me out
Thanks for the eclipse tips site
NAAG
Re: How to close Jface wizard while progress bar is running for a long time [message #335348 is a reply to message #335347] Fri, 03 April 2009 06:23 Go to previous messageGo to next message
Naag wrote:
> Hi prakash
> //Sample code
This is correct. By providing cancelable=true, the Cancel Button will be
enabled while the operation is running.
Here, you have to check monitor.isCanceled() after each call and throw
an InteruptedException when it is true. See the JavaDoc of
IRunnableWithProgress.
> monitor.done();
You have to catch the InteruptedException and close the wizard with
getShell().close().
This is a little bit ugly, as you make an assumption that the shell is
owned by the WizardDialog. In fact, a Wizard could be run by a container
that is no WizardDialog. For example, it could be run embedded in the
workbench window. Calling shell.close() here would have another meaning.
Anyway, WizardDialog is the only container I was using so far, and
AFAICS shell.close() is the only way of closing the wizard programmatically
> NAAG
Regards, Sebastian
Re: How to close Jface wizard while progress bar is running for a long time [message #335349 is a reply to message #335348] Fri, 03 April 2009 06:40 Go to previous messageGo to next message
Thanks for the reply. When i make the isCancelled flag as true there is no
cancel button enabled.
Re: How to close Jface wizard while progress bar is running for a long time [message #335351 is a reply to message #335349] Fri, 03 April 2009 07:42 Go to previous message
> is no cancel button enabled.
No, this is not what I said. You called getContainer().run(true, true,
new IRunnableWithProgress() {...} ). By providing true for the first two
arguments, the operation is cancelable and does not run on the UI thread
(in other words: the UI still responds while the op is running).
This alone should make your cancel button enabled, what means it can
actually be pressed. When the button is pressed by the user, the
IProgressMonitor.isCanceled() becomes true. Your Runnable should poll
this between method calls and break when it becomes true. The break can
be implemented by just throwing an InteruptedException.
Sebastian
Previous Topic:LTK: Need to replace DeleteResourcedRefactoringContribution
Next Topic:Problem updating Ganymede
Current Time: Thu Nov 06 15:10:49 EST 2025
Powered by FUDForum. Page generated in 0.03650 seconds
