Home » Eclipse Projects » Eclipse Platform » Feature Verification update warning dialog and Code Signing
Feature Verification update warning dialog and Code Signing [message #335330] Wed, 01 April 2009 14:03
I need to get rid of the Feature Verification warning dialog that pops up
during update for signed (untrusted?) features, that says this:
- You are about to install a signed feature
- The certificates used to authenticate this feature are not recognised
- The provider of this feature cannot be verified
I'm experimenting using a self-signed certificate (chain length of 2, had
to go through some hoops due to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258802) but I'm seeing the
dialog as described above which I need to get rid of as it's a B2C RCP app
and this will likely scare my users.
** So, if I purchase a code signing certificate will this be enough to
kill this dialog? Or will it just be replaced by something else?!
I'm thinking of getting a COMODO code signing certificate as Tucows are
reselling them for only $75pa (thanks to StackOveflow!
http://stackoverflow.com/questions/155241/cheapest-java-code -signing-certificate-not-self-signed).
If anyone has experience of using them would love to hear about it too!
Justin
Previous Topic:Enable launch shortcut depending on content type
Next Topic:Displsxing message of marker at caret position in status line
Current Time: Wed Nov 12 01:40:56 EST 2025
Powered by FUDForum. Page generated in 0.13861 seconds
