| Enable launch shortcut depending on content type [message #335328] |
Wed, 01 April 2009 12:04  |
Eclipse User  |
I want to enable the launch shortcut depending on the content type of
the selected file. In my plugin.xml, I defined the following:
    <!-- content type definition -->
    <extension
         point="org.eclipse.core.contenttype.contentTypes">
      <content-type
            base-type="org.eclipse.core.runtime.xml"
            file-extensions="mwe,oaw"
            id="org.eclipse.emf.mwe.ui.contentType.workflow"
            name="%contentType"
            priority="high">
            <describer
class=" org.eclipse.core.runtime.content.XMLRootElementContentDescri ber ">
                <parameter name="element" value="%rootElement"/>
            </describer>
      </content-type>
   </extension>
   <!-- launch shortcut -->
   <extension
         point="org.eclipse.debug.ui.launchShortcuts">
      <shortcut
            label="MWE Workflow"
            icon="icons/oawlaunch.gif"
            category="org.eclipse.ui.externaltools"
class=" org.eclipse.emf.mwe.internal.ui.eclipse.launch.MWELaunchShor tcut "
            modes="run, debug"
            id="org.eclipse.emf.mwe.ui.debug.launching.shortcut">
        <contextualLaunch>
           <enablement>
             <with variable="selection">
               <count value="1"/>
               <iterate
                     ifEmpty="false"
                     operator="and">
                  <adapt
                        type="org.eclipse.core.resources.IFile">
                  </adapt>
                  <test
                        forcePluginActivation="false"
property="org.eclipse.core.resources.contentTypeId"
value="org.eclipse.emf.mwe.ui.contentType.workflow">
                  </test>
               </iterate>
             </with>
           </enablement>
           <contextLabel
         	  mode="run"
         	  label="MWE Workflow"/>
          <contextLabel
         	  mode="debug"
  		 </contextualLaunch>
      </shortcut>
   </extension>
However, if I enable the commented out test, the launch shortcut is
never available.
What am I missing?
Patrick
Patrick Schönbach
Software Architect
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C  902D 62A6 806A 0B7D DE39
web: http://www.itemis.de
mail: schoenbach@itemis.de
xing: https://www.xing.com/profile/Patrick_Schoenbach
itemis AG
Schauenburgerstraße 116
24118 Kiel
Germany
Rechtlicher Hinweis:
Amtsgericht Dortmund, HRB 20621
Vorstand: Wolfgang Neuhaus, Jens Wagener, Dr. Georg Pietrek
Aufsichtsrat: Dr. Burkhard Igel(Vors.), Stephan Grollmann, Michael
Neuhaus
FUDForum. Page generated in 0.03857 seconds
