Home » Eclipse Projects » Eclipse Platform » Why is C'tor of UIElement protected?
Why is C'tor of UIElement protected? [message #335297] Tue, 31 March 2009 07:25 Go to next message
I'm using a custom self written control (HyperlinkMenu). I successfully
pluged my control into the Eclipse IHandlerService, so enablement and
disablement of commands are getting tracked and displayed by the control
(Using a HyperlingMenuManager and a HyperlinkMenuContributionItem).
Currently I wand so participate from IElementUpdater and therefore use
UIElement since (I think) using it is the only way to get the
updateElement() of IElementUpdater events passed to my control.
Unfortunately the constructor of UIElement is protected. So without having
to use Java reflection it is impossible for me to use it (I think).
Is there any good reason why the Class is unusable from outside?
And does someone know a way how to take advantage from IElementUpdater
without using hacks like reflections?
If anybody is interested in HyperlinkMenu just reply and I'll post it.
Jan
Re: Why is C'tor of UIElement protected? [message #335307 is a reply to message #335297] Tue, 31 March 2009 12:14 Go to previous message
UIElement is API, but it must be subclassed. Either a typed subclass or
an anonymous subclass works fine.
PW
Paul Webster
Previous Topic:[menus] submenu in popup menu does not show up when manually populated
Next Topic:Adding filter in Project Explorer
Current Time: Sat Nov 15 19:45:18 EST 2025
Powered by FUDForum. Page generated in 0.25857 seconds
