Home » Eclipse Projects » Eclipse Platform » Adding filter in Project Explorer
Adding filter in Project Explorer [message #335281] Mon, 30 March 2009 11:43 Go to next message
Hi all,
I want to add some filters in project explorer view.
I've tried "org.eclipse.ui.ide.resourceFilters" extension point, it's
working for navigator view but not for project explorer.
Someone has ideas?
Thanks in advance.
Hugues
Re: Adding filter in Project Explorer [message #335283 is a reply to message #335281] Mon, 30 March 2009 11:51 Go to previous messageGo to next message
Hugues Rérolle wrote:
> Hi all,
> Someone has ideas?
This extension point is for the Navigator only. For the Project Explorer
see: org.eclipse.ui.navigator.navigatorContent
Dani
> Thanks in advance.
> Hugues
Re: Adding filter in Project Explorer [message #335284 is a reply to message #335283] Mon, 30 March 2009 13:04 Go to previous messageGo to next message
Originally posted by: francis.oaklandsoftware.com
Look at the links in the bottom of my signature, the first one has the
complete documentation for the Common Navigator of which the Project
Explorer is an instance.
On Mon, 30 Mar 2009 08:51:44 -0700, Daniel Megert
>> Hi all,
>> Someone has ideas?
> Dani
>> Thanks in advance.
>> Hugues
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Adding filter in Project Explorer [message #335308 is a reply to message #335283] Tue, 31 March 2009 13:30 Go to previous message
I use commonFilter of org.eclipse.ui.navigator.navigatorContent
extension point, and now it's working.
Thanks!
Hugues
>> Hi all,
>> Someone has ideas?
> Dani
>> Thanks in advance.
>> Hugues
Previous Topic:Why is C'tor of UIElement protected?
Next Topic:dynamically updating plugin classpath
Current Time: Fri Nov 07 11:20:58 EST 2025
Powered by FUDForum. Page generated in 0.04213 seconds
