Home » Eclipse Projects » Eclipse Platform » [CNF] Tabbed Properties in Common Navigator
[CNF] Tabbed Properties in Common Navigator [message #335276] Mon, 30 March 2009 10:39 Go to next message
--------------070407030702030705070708
Content-Type: text/plain; charset=ISO-8859-15
Hi!
I am stuck with a little problem regarding CNF and the tabbed properties
view. As I have found out, I have to register a contributor in
plugin.xml that has the same id as the CommonViewer. I followed the
Tabbed Properties article on the eclipse site, bit didn't manage to get
it work. Debugging showed that neither the Contributor's nor the
Section's code is actually invoked at any time.
The effect is that I get the properties view showing the well-known
"Properties are not available"
My plugin.xml is like this (only showing relevant parts):
<view allowMultiple="false"
category="org.example.my.mycat"
class="org.eclipse.ui.navigator.CommonNavigator"
icon="icons/application_side_tree.png"
id="org.example.my.mynavigator"
name="My Example Navigator"
restorable="true">
</view>
<propertyContributor contributorId="org.example.my.mynavigator">
<propertyCategory category="org.example.my.test">
</propertyCategory>
</propertyContributor>
<propertyTabs contributorId="org.example.my.mynavigator">
<propertyTab
id="org.example.my.mynavigator.propertyTab1"
image="icons/item.png"
label="A tab">
</propertyTab>
</propertyTabs>
<propertySections contributorId="org.example.my.mynavigator">
<propertySection
class="org.example.my.NavPropSection"
id="org.example.my.navisection"
tab="org.example.my.mynavigator.propertyTab1">
</propertySection>
</propertySections>
Hopefully I didn't miss anything. I have created a contributor class,
but that seems redundant, since it is not registered anywhere in the
plugin.xml. I also tried an approach with an AdapterFactory that didn't
work either.
Can anyone help me? Or point me to the right direction?
That would be greatly appreciated.
Thanks in advance
Andreas
Content-Type: text/x-vcard; charset=utf-8;
name="as_maps.vcf"
Content-Disposition: attachment;
filename="as_maps.vcf"
begin:vcard
fn:Andreas Schoeneck
n:Schoeneck;Andreas
email;internet:as.maps@gmail.com
x-mozilla-html:FALSE
version:2.1
end:vcard
--------------070407030702030705070708--
Re: [CNF] Tabbed Properties in Common Navigator [message #335293 is a reply to message #335276] Tue, 31 March 2009 06:14 Go to previous message
What I missed was the input element under propertySection...
Andreas Schoeneck schrieb:
> Hi!
> restorable="true">
> </view>
> </propertyCategory>
> <propertyTab
> label="A tab">
> </propertyTab>
> </propertyTabs>
> <propertySection
> </propertySection>
> </propertySections>
> work either.
> Thanks in advance
> Regards
> Andreas
Previous Topic:Delete project takes long time
Next Topic:Register a "New Wizard" programmatically?
Current Time: Fri Jul 11 21:17:36 EDT 2025
Powered by FUDForum. Page generated in 0.04692 seconds
