Home » Eclipse Projects » Eclipse Platform » Tracking every action in eclipse
Tracking every action in eclipse [message #335250] Fri, 27 March 2009 13:36 Go to next message
i want to create an action trace. This trace should fetch every user
action. I tried it with event filter such like this:
Display display = Display.getDefault();
display.addFilter(SWT.MouseDown, new EventListener("MouseDown Event"));
But these listeners dont give me the corresponding plugin, i get only
the mouse down information wihtout the consequence. Can you give me a
hint? I would be very glad about some help.
Greetings
Re: Tracking every action in eclipse [message #335260 is a reply to message #335250] Fri, 27 March 2009 18:39 Go to previous messageGo to next message
Originally posted by: n.n.nnn
On Fri, 27 Mar 2009 18:36:53 +0100, Jörg wrote:
> Hello,
> Display display = Display.getDefault(); display.addFilter(SWT.MouseDown,
> Greetings
Try implementing a base action class extending from
org.eclipse.jface.action.Action
and from there override one or more of the Action class
methods in the base to hook into the workbench. Finally
do the actual work of the action:
private Action traceMeAction;
traceMeAction = new ActionTracer("Trace Me") {
public void run() {
// trace this
super.run();
// now do the actual action work
// TODO
register(traceMeAction);
in ApplicationActionBarAdvisor().
// This is my opinion.
Re: Tracking every action in eclipse [message #335264 is a reply to message #335250] Sat, 28 March 2009 12:15 Go to previous messageGo to next message
You can trace the commands by registering a command listener, but not sure
whether you can do that for actions.
http://blog.eclipse-tips.com/2009/01/commands-part-4-misc-it ems.html
- Prakash
Re: Tracking every action in eclipse [message #335265 is a reply to message #335260] Sat, 28 March 2009 14:49 Go to previous messageGo to next message
> @Override
> public void run() {
> // trace this
> super.run();
> // TODO
PS Take out that register, throws an exception, works without it.
Re: Tracking every action in eclipse [message #335294 is a reply to message #335265] Tue, 31 March 2009 06:49 Go to previous messageGo to next message
Thanks for your reply, but this helps only by my own created actions.
Ist it possible to initialize a general actionlistner, which catches
every action in eclipse?
>> @Override
>> public void run() {
>> // trace this
>> super.run();
>> // TODO
Re: Tracking every action in eclipse [message #335295 is a reply to message #335264] Tue, 31 March 2009 07:04 Go to previous messageGo to next message
Thanks this helped a little bit. actually the commands are only triggert
when a file is be deleted.
> - Prakash
Re: Tracking every action in eclipse [message #335315 is a reply to message #335294] Tue, 31 March 2009 17:24 Go to previous messageGo to next message
I see your point, perhaps someone reading this thread is aware of the
best solution. Good luck!
Re: Tracking every action in eclipse [message #335323 is a reply to message #335315] Wed, 01 April 2009 08:54 Go to previous message
hi,
You might want to have a look on the Usage Data Collector component as that's what it's exactly doing AFAIK.
Cédric
Previous Topic:Debugging products without including extra plugins?
Next Topic:Team logical model
Current Time: Sat Nov 01 16:02:56 EDT 2025
Powered by FUDForum. Page generated in 0.04747 seconds
