Home » Eclipse Projects » Eclipse Platform » Project clean event?
Project clean event? [message #335244] Fri, 27 March 2009 11:15 Go to next message
Is there a way to capture when a project clean occurs *other* than adding
a builder? We don't "build" anything, but we do want to know when it
occurs, especially a clean.
A resource listener isn't quite enough, because if no resource changes,
then there is no post build event.
Re: Project clean event? [message #335248 is a reply to message #335244] Fri, 27 March 2009 12:21 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There is a clean event in the resources listener.
> adding a builder? We don't "build" anything, but we do want to know
> when it occurs, especially a clean.
Rich Kulp
Re: Project clean event? [message #335249 is a reply to message #335248] Fri, 27 March 2009 12:55 Go to previous messageGo to next message
You mean the getBuildKind() query? If so, I do know about that, but the
problem is that the POST_BUILD event will not be broadcast if there are no
resource changes (if there is no resource delta). So this method of
capturing that a clean has happened is not reliable. I would like to know
*every* time a clean has been invoked, whether or not resources are
changed as a result.
Rich Kulp wrote:
Re: Project clean event? [message #335251 is a reply to message #335249] Fri, 27 March 2009 14:02 Go to previous messageGo to next message
Then capture pre_build instead of post_build.
> no resource changes (if there is no resource delta). So this method of
> know *every* time a clean has been invoked, whether or not resources are
> Rich Kulp wrote:
>>> changes, then there is no post build event.
Rich Kulp
Re: Project clean event? [message #335252 is a reply to message #335251] Fri, 27 March 2009 14:17 Go to previous messageGo to next message
I didn't mention pre_build because we're more interested in doing
something after the build has been launched, but it does suffer from the
same problem as post_build. If there are no resource changes since the
last build, there is no event.
>> Rich Kulp wrote:
>>> Hi,
Re: Project clean event? [message #335253 is a reply to message #335252] Fri, 27 March 2009 14:51 Go to previous messageGo to next message
I don't think that's true, or something has changed. I was the one that
requested the Clean notification to be put in several years ago. It's
purpose was to let me know a clean was requested so that I could delete
some files in metadata area. I received notifications no matter whether
any files had changed or been deleted or not.
>>> the problem is that the POST_BUILD event will not be broadcast if
>>> there are no resource changes (if there is no resource delta). So
>>> this method of capturing that a clean has happened is not reliable.
>>> I would like to know *every* time a clean has been invoked, whether
>>> or not resources are changed as a result.
>>> Rich Kulp wrote:
>>>> Hi,
>>>>> know when it occurs, especially a clean.
Rich Kulp
Re: Project clean event? [message #335255 is a reply to message #335253] Fri, 27 March 2009 16:10 Go to previous messageGo to next message
OK, found the problem and you're right.
I was basing this off of this prior posting:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg68 578.html
most of which seems correct when looking at the code.
I was also *never* receiving either a pre or post_build event so I assumed
it was true. You clued me in to looking at the listener registration a
bit closer. We haven't needed to look at build events prior to this, so
our usage of:
workspace.addResourceChangeListener(listener);
didn't show any problems.
Using:
workspace.addResourceChangeListener(resourceChangeListener,
IResourceChangeEvent.PRE_CLOSE | IResourceChangeEvent.PRE_DELETE |
IResourceChangeEvent.POST_CHANGE | IResourceChangeEvent.POST_BUILD);
fixes our problems. I now always receive a post_build event. I assume
having the first method solved some backwards compatibility problem for
some users at some point. Never would I have guessed that the first
method would be equivalent to calling the second with some arbitrary (to
someone) subset of flags.
Thanks for helping,
- Paul
Re: Project clean event? [message #335256 is a reply to message #335255] Fri, 27 March 2009 17:43 Go to previous message
Hi Paul,
I'm glad you found your answer. :-)
Rich Kulp
Previous Topic:Wizard questions
Next Topic:refresh not working properly
Current Time: Tue Jul 15 12:00:10 EDT 2025
Powered by FUDForum. Page generated in 0.04574 seconds
