[Compare Editor] DiffViewer doesn't refresh with custom CompareEditorInput [message #335212] |
Wed, 25 March 2009 23:21  |
I need to provide a custom CompareEditorInput to the compare editor. I
created left and right inputs that implements ITypedElement,
IStreamContentAccessor and IEditableContent. In the prepareInput method of
the custom CompareEditorInput, these left and right inputs are used as
left and right sides of a DiffNode. I am able to successfully open the
editor. However, the diff viewer in the compare editor doesn't refresh
(doesn't show the differences) when changes are made in the editor.
I looked at the source code and I believe the reason is due to the
contents not being flushed to the input elements via the content provider
in ContentMergeViewer. This is due to the instanceof check done for the
diff node. The check is made against ResourceCompareInput.MyDiffNode in
the saveLeftContent and saveRightContent methods in
MergeViewerContentProvider and the fireChange method is never called.
fireChange is never called from saveLeftContent method saveRightContent
methods in MergeViewerContentProvider due to below instanceof check
if (node instanceof ResourceCompareInput.MyDiffNode)
((ResourceCompareInput.MyDiffNode)node).fireChange();
What is the best way to get around this issue? Is there a way I can
contribute my own provider?
Any help is greatly appreciated.
Re: [Compare Editor] DiffViewer doesn't refresh with custom CompareEditorInput [message #335463 is a reply to message #335451] |
Thu, 09 April 2009 09:08  |
Shankar,
I am no longer involved in the maintenance of the Compare framework so I
cannot make any statements about when features may be available. Also, I
do not know of any way currently for you to realize live updates. The
best way to get a response from the Compare developers would be to open
a bug report.
Michael
Shankar wrote:
> Thanks for the prompt response, Michael. It seems like a common use case
> to be able to invoke the eclipse compare editor programmatically (from a
> custom plug-in) and make changes to the compare editor. Is there any way
> I can realize the live difference update in the compare editor?
> Can you please let me know when this feature would be available? Please
> note that I am using Eclipse 3.3.
> Michael Valenta wrote:
>> Shankar,
>> I don't believe that the compare framework supports "live" difference
>> update when changes are made in an editor. I believe you need to save
>> the editor to have the diff recomputed. I seem to recall that there
>> were already bugs entered for this so you may want to search in bugzilla.
>> In regards to the hard-coded reference to
>> ResourceCompareInput.MyDiffNode, I belivee this is a hack to make the
>> Compare with/Each Other work when performed on folders. There are
>> already bugs for that as well.
>> Michael
>> Shankar wrote:
>>> Would appreciate any help on the below. Am really stuck - the diff
>>> viewer in the compare editor doesn't refresh due to the instanceof
>>> check (hard-coded to ResourceCompareInput.MyDiffNode). However, I
>>> provide my own compare input. Any thoughts please?
>>> Shankar wrote:
>>>> Hello,
>>>> I created left and right inputs that implements ITypedElement,
>>>> method of the custom CompareEditorInput, these left and right inputs
>>>> are used as left and right sides of a DiffNode. I am able to
>>>> successfully open the editor. However, the diff viewer in the
>>>> compare editor doesn't refresh (doesn't show the differences) when
>>>> provider in ContentMergeViewer. This is due to the instanceof check
>>>> done for the diff node. The check is made against
>>>> ResourceCompareInput.MyDiffNode in the saveLeftContent and
>>>> saveRightContent methods in MergeViewerContentProvider and the
>>>> saveRightContent methods in MergeViewerContentProvider due to below
>>>> instanceof check
FUDForum. Page generated in 0.04216 seconds
