Home » Eclipse Projects » Eclipse Platform » Problem with 3.5 rewriting eclipse.ini
Problem with 3.5 rewriting eclipse.ini [message #335166] Tue, 24 March 2009 12:19 Go to next message
Originally posted by: no.ddress.here
Eclipse 3.5M6 on WinXP
Whenever I use Help->Check for Updates or Help->Install New Software
(and actually update/install something), Eclipse appears to rewrite the
eclipse.ini VM line incorrectly, at least for Windows.
Before running Update/Install, my eclipse.ini contains the line:
-vm
C:/Program Files/Java/jdk1.6.0_11/bin/javaw.exe
After update/install and closing Eclipse, the line has been changed to:
-vm
file:/C:/Program Files/Java/jdk1.6.0_11/bin/javaw.exe
And, on the next cold start of Eclipse, Eclipse complains that it cannot
find a JRE in "file:/C:/Program Files/Java/jdk1.6.0_11/bin/javaw.exe"
Bug?
Re: Problem with 3.5 rewriting eclipse.ini [message #335237 is a reply to message #335166] Thu, 26 March 2009 14:22 Go to previous messageGo to next message
> -vm
> -vm
> Bug?
Could be, but for me it uses a relative path. My eclipse.ini ends up
looking like this:
-vm
.../../../../java/JDK/1.6.0/bin/javaw.exe
I'm not sure what is the purpose of the re-writing in the first place;
it certainly seems like a bug to do it at all. Makes it a pain to move
around either Eclipse installations or JVM installations (both of which
I've done without worry in the past).
If you find or enter a bug report, please post the link here.
Eric
Re: Problem with 3.5 rewriting eclipse.ini [message #335262 is a reply to message #335237] Sat, 28 March 2009 11:34 Go to previous message
In article <gqgh5e$ss7$1@build.eclipse.org>, eclipse-news@rizzoweb.com
says...>
> > -vm
> > -vm
> > Bug?
> looking like this:
> -vm
> Eric
https://bugs.eclipse.org/bugs/show_bug.cgi?id=270353
Gerald
Previous Topic:refresh not working properly
Next Topic:gettting the name of the selected object in the Objectactiondelegate class
Current Time: Tue Nov 04 16:29:04 EST 2025
Powered by FUDForum. Page generated in 0.03381 seconds
