riena server outside eclipse [message #2901] |
Thu, 22 May 2008 03:49  |
hi
i have a riena server and rcp application/riena client
they work perfectly well when i launch them within eclipse
but when i try to export my server plugins and launch them directly , it
failed
with "unresolved compilation problem"
and unresolved "import" problem
i have to say , i'm using hibernate. and that's really a pain to setup up
the
manifest file for this plug-in and the one that are using it
has someone got a step by step guide to export and launch a riena server ??
or does someone succeded in this task ??
tia
David
Re: riena server outside eclipse [message #3063 is a reply to message #2901] |
Mon, 26 May 2008 19:05  |
maybe I am getting this wrong. But it seems you are actually asking two questions.
how to create a WAR file for the Riena server ?
how to create the manifest.mf for Hibernate ?
Riena Server is no different than any equinox based application in a servlet container. So you can use a standard
description how to set up the WAR file like this one I googled.
http://www.eclipse.org/equinox/server/http_in_container.php
This should work and if not let me know, what the problem is
About hibernate there is a little bit of an issue that you also have with other persistence frameworks or
even with remote services.
it is about using buddies. hibernate needs to be able to look up classes by name in each bundle that contain
you persistance class code. since you cannot and should not make hibernate dependant on any of your business classes
that problem is solvede with buddies. hibernate's manifest.mf must specify in an extra line
Eclipse-BuddyPolicy: registered
and all business plugins must say
Eclipse-RegisterBuddy: org.hibernate (or whatever your the plugin id of hibernate is that you choose)
also (very imporant)
your business plugins must be defined as dependant on the hibernate plugin (otherwise Buddy dont work)
was that of any help ?
if not, give me some details of the problem you are having
christian campo
news.eclipse.org schrieb:
> hi
> failed
> up the
> tia
> David
Re: riena server outside eclipse [message #571355 is a reply to message #2901] |
Thu, 22 May 2008 07:02  |
Originally posted by: ekkehard.gentz-software.de
david,
sorry - I cannot help at the moment -
perhaps in 1 week or so.
one question:
are you using only riena server for remote services
or are you also using Riena ObjectTransactions
together with hibernate )
ekke
Re: riena server outside eclipse [message #571413 is a reply to message #2937] |
Fri, 23 May 2008 05:41  |
I'll let you know if I have figured out all issues to make my solution run:
RCP client with Eclipse DataBinding
Riena Server, Hibernate/JPA, jBPM, Drools
and using ObjectTransactions between client/server
ekke
news.eclipse.org wrote:
> just for remote services
> "ekke" <ekkehard@gentz-software.de> wrote in message
> news:06f3d24acf20ef19ba35c9fbb8985e76$1@www.eclipse.org...
>> david,
>> one question:
>> ekke
Re: riena server outside eclipse [message #571436 is a reply to message #2954] |
Fri, 23 May 2008 06:02  |
ok thanks
have you got some documentation on object transaction ?
there is no links on riena wiki
news:a62a21a91aa53a29ab826988a7b4e1c0$1@www.eclipse.org...
> run:
> Riena Server, Hibernate/JPA, jBPM, Drools and using ObjectTransactions
> ekke
>>> david,
>>> one question:
>>> ekke
Re: riena server outside eclipse [message #571474 is a reply to message #2971] |
Fri, 23 May 2008 06:06  |
you have to go thru the unit tests
and look inside the code - its well documented
of course, a Getting Started with ObjectTransactions is missing on riena
wiki
and I hope the Riena team is working on it
I'll publish some things next days what I found out
and the solutions for my application
ekke
> ok thanks
>> run:
>> ekke
>>>> david,
>>>> one question:
>>>> ekke
Re: riena server outside eclipse [message #571644 is a reply to message #2901] |
christian campo
> hi
> failed
> up the
> tia
> David
FUDForum. Page generated in 0.22185 seconds
