Home » Eclipse Projects » Eclipse Platform » why the old bundle loaded
why the old bundle loaded [message #335148] Tue, 24 March 2009 04:53 Go to next message
Hi, all
I'm developing an IDE that involves several bundlers, everything works
fine except that some time eclipse did not load the newest bundlers.
My eclipse is 3.4 (and the problem remained on 3.5)
I deploy the bundlers in link style, and I put the link file into the
"dropins" folder.
And especially, the problem occurs when the bundler version is slightly
updated, that said, only the qualifier part of the version changed:
x.y.plugin_1.0.0.R20090322-1000, to
x.y.plugin_1.0.0.R20090324-1000
And I did not delete the old bundlers intendedly, so, the old bundlers are
come with the new one under the same plugin folder.
I tried use the -clean argument, but the problem is remained.
Any help?
Thanks & Best Regards!
--------ooO--(_)--Ooo--------
| Nick Tan |
Re: why the old bundle loaded [message #335190 is a reply to message #335148] Wed, 25 March 2009 10:41 Go to previous messageGo to next message
Does the new version of the plugin adds any new dependencies or compiled
with a different execution environment?
- Prakash
http://blog.eclipse-tips.com
Re: why the old bundle loaded [message #335208 is a reply to message #335190] Wed, 25 March 2009 21:36 Go to previous message
Thanks for your reply
There's no new dependencies added, and the the deployed plugins are produced
by the dailybuild process which build on eclipse 3.3
BTW, even that new dependencies added or dependencies changed, how to
recover from this scenario?
In eclipse 3.3, I simply delete all folder/files under
${ECLIPSE_HOME}/configuration except config.ini and .settings, and restart
eclipse with "-clean" argument.
But in eclipse 3.4 or above, it does not take effect, I think maybe it's
because of new update management framework (or P2)?
"Prakash G.R." <grprakash@gmail.com> 写入消息
news:gqdfra$v96$1@build.eclipse.org...
> - Prakash
Previous Topic:workingSets and headless environments
Next Topic:Re: Active Project Handling - Howto
Current Time: Sat Nov 15 15:33:48 EST 2025
Powered by FUDForum. Page generated in 0.03845 seconds
