Home » Eclipse Projects » Eclipse Platform » FormText Tabbing.
FormText Tabbing. [message #335104] Mon, 23 March 2009 09:10 Go to next message
I am using a FormText control to display some labels, however, I want to
prevent tab to enter into this control at all. Today it enters but does
not show the cursor. I want the tab key to completely skip the FormText
Control.
Since I do not have direct access to the FormText code, I tried to add a
listener for Tab key and reflectively invoke the "advance" method on it as
follows, but this does not work either.
label1.addListener(SWT.Traverse, new Listener() {
public void handleEvent(Event e) {
if (e.detail == SWT.TRAVERSE_TAB_NEXT) {
try {
Object obj = //reflective call to Advance
e.doit = ((Boolean)obj).booleanValue();
I will really appreciate if someone can tell me what to do here and how to
resolve this issue.
Irum.
Re: FormText Tabbing. [message #335158 is a reply to message #335104] Tue, 24 March 2009 09:53 Go to previous messageGo to next message
On 3/23/2009 9:10 AM, Irum Godil wrote:
> Control.
> as follows, but this does not work either.
> try {
> to resolve this issue.
Have a look at TraverseListener and TraverseEvent.
Hope this helps,
Eric
Re: FormText Tabbing. [message #335194 is a reply to message #335158] Wed, 25 March 2009 10:44 Go to previous messageGo to next message
I did look at the classes mentioned by you, but it does not solve my
problem exactly. Basically, I have 2 controls in my form, one is a
FormText, and the other can be any SWT/more complex widget.
I actually have a series of them, so something like:
Label1 Text
Label2 Combo
Label3 Something more complex
Now, what I want is that the tab always comes in the 2nd field, but skips
all the labels.
If I set e.doit = false, for the labels, then the tab does not continue
past the first label. If I set it to true, I see the same behaviour as
today.
How can I just skip tab from the FormText, but ensure it goes to the next
control on the page?
Thanks for your responses.
Irum.
Re: FormText Tabbing. [message #335231 is a reply to message #335194] Thu, 26 March 2009 12:59 Go to previous messageGo to next message
Irum Godil wrote:
> Label1 Text
> Label2 Combo
> all the labels.
> today.
> Irum.
I was hoping if someone can please help me on this one, or direct me to
some resources where I can find the solution.
Really appreciate your help.
Irum.
Re: FormText Tabbing. [message #335233 is a reply to message #335194] Thu, 26 March 2009 14:05 Go to previous messageGo to next message
On 3/25/2009 10:44 AM, Irum Godil wrote:
> Label1 Text
> Label2 Combo
> skips all the labels.
> today.
> next control on the page?
I don't understand; Label widgets don't take focus (on Windows, at
least). So the default focus traversal for a Composite should
automatically find the "next" focusable control.
Eric
Re: FormText Tabbing. [message #335235 is a reply to message #335233] Thu, 26 March 2009 14:11 Go to previous messageGo to next message
>> Label1 Text
>> Label2 Combo
>> today.
> Eric
In my example, the Labels are actually "FormText" object and they are
taking focus, although I do not see any cursor.
Thanks.
Re: FormText Tabbing. [message #335444 is a reply to message #335235] Wed, 08 April 2009 10:28 Go to previous message
I was wondering if someone was able to think of a solution to this one. I
will appreciate any inputs.
Irum.
Previous Topic:refreshing commands based on workbench selection
Next Topic:Hide filter in FilteredTree
Current Time: Tue Jul 15 00:29:40 EDT 2025
Powered by FUDForum. Page generated in 0.05642 seconds
