Home » Eclipse Projects » Eclipse Platform » my 3.3 plugin doesn't work in 3.4
my 3.3 plugin doesn't work in 3.4 [message #335054] Thu, 19 March 2009 12:58 Go to next message
A plugin I wrote under Eclipse 3.3 does not work in 3.4 - it looks like the
plugin is not activated. I did update MANIFEST.MF to include the following:
Bundle-ActivationPolicy: lazy
But it doesn't work whether the old or new line is present. My plugin
overrides editor hover behavior. I specify the extension point
org.eclipse.jdt.ui.javaEditorTextHovers in plugin.xml. That looks like
this:
<?eclipse version="3.4"?>
<plugin>
<extension point="org.eclipse.jdt.ui.javaEditorTextHovers">
<hover
id="myEditorHover"
class="sonif.myEditorHover"
label="lewisCustomHover"
description="A custom hover handler."
activate="true" >
</hover>
</extension>
</plugin>
Any ideas why my plugin is not activated?
Lewis Berman
Loyola University in Maryland
Re: my 3.3 plugin doesn't work in 3.4 [message #335068 is a reply to message #335054] Fri, 20 March 2009 04:29 Go to previous messageGo to next message
> this:
> <plugin>
> <hover
> id="myEditorHover"
> activate="true" >
> </hover>
> </extension>
> </plugin>
No idea. Try with 3.5 M6 and if it is not working there file a bug
report and attach your plug-in.
Dani
Re: my 3.3 plugin doesn't work in 3.4 [message #335079 is a reply to message #335068] Fri, 20 March 2009 09:58 Go to previous messageGo to next message
It is possible that my plugin is not activated because certain code has been
deprecated. I could at least test to see if it's activation works on
demand. Does Eclipse accept any activation policy other than lazy? If so,
what do I substitute for "lazy" in:
Lewis Berman
Re: my 3.3 plugin doesn't work in 3.4 [message #335161 is a reply to message #335079] Tue, 24 March 2009 10:06 Go to previous message
Hi Lewis,
You can easily check if your plug-in is activated by setting a printout
in the "start()" method in your plug-in "Activator.java" class. If your
message appears in the console, your plug-in is started. Your problem
could be related to deprecated code, or perhaps a deprecated extension
point...
If the activation is not lazy, the "Bundle-ActivationPolicy: lazy" line
in your Manifest.MF is deleted.
Mircea
Previous Topic:IWorkBenchPropertyPages and disabling/enabling based on content
Next Topic:How to check the consistency of the Platform ?
Current Time: Thu Jul 17 00:58:56 EDT 2025
Powered by FUDForum. Page generated in 0.03503 seconds
