Home » Eclipse Projects » Eclipse Platform » Registering own IDocumentProvider
Registering own IDocumentProvider [message #335031] Tue, 17 March 2009 09:19 Go to next message
Hello!
Let me describe my problem.
1 .I have my own IStorageEditorInput, which provides editing some string
without openning IFile
public class SimpleEditorInput implements IStorageEditorInput {
private String inputString;
public SimpleEditorInput(String inputString) {
this.inputString = inputString;
public IStorage getStorage() throws CoreException {
return new IStorage() {
public InputStream getContents() throws CoreException {
return IOUtils.toInputStream(inputString);
public IPath getFullPath() {
return null;
public String getName() {
return SimpleEditorInput.this.getName();
public boolean isReadOnly() {
return false;
public Object getAdapter(Class adapter) {
return null;
public boolean exists() {
return true;
public ImageDescriptor getImageDescriptor() {
return ImageDescriptor.getMissingImageDescriptor();
return "JSEditor";
public IPersistableElement getPersistable() {
return null;
public String getToolTipText() {
return "JSEditor Tool Tip Text";
return null;
public void setInputString(String inputString) {
2. Next, I'm opennig any Editor (for example:
window.getActivePage().openEditor(new
SimpleEditorInput(TEST_JS_1),"org.eclipse.ui.DefaultTextEditor ");
or
SimpleEditorInput(TEST_JS_1),"org.eclipse.wst.jsdt.ui.CompilationUnitEditor ");
3. The problem is, that I'd like to process SAVE action. But default
provider for my EditorInput is StorageDocumentProvider, which
doSaveDocument method is empty:
protected void doSaveDocument(IProgressMonitor monitor, Object
element, IDocument document, boolean overwrite) throws CoreException {
So, I'm trying to register my own DocumentProvider:
public class StringStorageDocumentProvider extends StorageDocumentProvider
... here do something ...
by placing in my plugin.xml this block:
<extension
point="org.eclipse.ui.editors.documentProviders">
<provider
class="test.jseditor.StringStorageDocumentProvider"
inputTypes="org.eclipse.ui.IStorageEditorInput"
id="test.jseditor.StringStorageDocumentProvider">
</provider>
</extension>
But this doesn't work!
Please, help me. What do I wrong?
Re: Registering own IDocumentProvider [message #335047 is a reply to message #335031] Thu, 19 March 2009 06:37 Go to previous message
Andrew Arapov wrote:
> Hello!
See my answer in eclipse.platform.rcp.
Dani
> string without openning IFile
> return null;
> return false;
> return null;
> return true;
> return "JSEditor";
> return null;
> return null;
> or
> StorageDocumentProvider {
> @Override
> <extension
> <provider
> </provider>
> </extension>
Previous Topic:Toggle Menu Item
Next Topic:Annotation for problemMarkers
Current Time: Sun Nov 16 20:54:38 EST 2025
Powered by FUDForum. Page generated in 0.03862 seconds
