Home » Eclipse Projects » Eclipse Platform » DataBinding allow only digit?
DataBinding allow only digit? [message #334982] Fri, 13 March 2009 12:16 Go to next message
I am starting to use jface databinding in my app.
I would want to put a restrict on field Text for allow only digit, not char.
I found a snippet in swt like this:
However, I would put this restriction inside IValidator with binding. It
is possible?
Re: DataBinding allow only digit? [message #334983 is a reply to message #334982] Fri, 13 March 2009 12:17 Go to previous messageGo to next message
> char.
> It is possible?
The snipper code is:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet19.java?view=co
Re: DataBinding allow only digit? [message #334991 is a reply to message #334983] Fri, 13 March 2009 14:00 Go to previous messageGo to next message
>> char.
>> It is possible?
DataBinding can handle this kind of thing easily, just set an IValidator
on the UpdateValueStrategy that you use when binding your widget to your
model.
The package org.eclipse.core.internal.databinding.validation has a bunch
of useful IValidator implementations for you to use, or you can write
your own.
The Data Binding snippets page
http://wiki.eclipse.org/JFace_Data_Binding/Snippets has some examples of
using validation.
Hope this helps,
Eric
Re: DataBinding allow only digit? [message #334995 is a reply to message #334991] Sat, 14 March 2009 05:13 Go to previous messageGo to next message
>>> char.
>>> It is possible?
> IValidator on the UpdateValueStrategy that you use when binding your
> widget to your model.
> bunch of useful IValidator implementations for you to use, or you can
> write your own.
> of using validation.
> Hope this helps,
> Eric
Thanks Eric,
I had just look IValidator, but it not prevent the user to insert a
wrong char. It signal to user that the string insert is wrong, but not
prevent to insert that. Example: I've a BigDecimal field as model and a
SWT Text field as Input, if the user insert "23.2a5" the IValidator
signal to the ui of the wrong string. But i would that when the user
insert "a" char the ui prevent to insert it as the snippet
do.
More, is possible with databinding formating the string? As example
currency, date, time etc
Thanks again
Stefano
Re: DataBinding allow only digit? [message #335005 is a reply to message #334995] Sun, 15 March 2009 13:02 Go to previous messageGo to next message
This use case is not supported by DataBinding--you need to filter input
at the widget. You want to either use an SWT.Verify [1] listener on the
Text control, or use the FormattedText [2] control from Nebula.
Matthew
[1]
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet19. java
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet179 .java
[2] http://www.eclipse.org/nebula/widgets/formattedtext/formatte dtext.php
>>>> char.
>>>> It is possible?
>> write your own.
>> Hope this helps,
>> Eric
> Thanks Eric,
> do.
> Thanks again
> Stefano
Re: DataBinding allow only digit? [message #335006 is a reply to message #335005] Mon, 16 March 2009 03:38 Go to previous messageGo to next message
Thanks Matthew,
you confirm my supposition
> input at the widget. You want to either use an SWT.Verify [1]
> listener on the Text control, or use the FormattedText [2] control
> from Nebula.
> Matthew
> [1]
>>>>> not
>>>>> char.
>>>>> It is possible?
>>> can write your own.
>>> examples of using validation.
>>> Hope this helps,
>>> Eric
>> Thanks Eric,
>> not prevent to insert that. Example: I've a BigDecimal field as model
>> and a SWT Text field as Input, if the user insert "23.2a5" the
>> IValidator signal to the ui of the wrong string. But i would that
>> when the user insert "a" char the ui prevent to insert it as the
>> snippet
>> do.
>> Thanks again
>> Stefano
Re: DataBinding allow only digit? [message #335017 is a reply to message #334995] Mon, 16 March 2009 14:22 Go to previous message
>>>> char.
>>>> It is possible?
>> write your own.
>> Hope this helps,
>> Eric
> Thanks Eric,
> do.
I don't understand - why don't you just use the code from that snippet?
It has nothing to do with data binding, it just works.
Look at ComputedValue (again, the snippets page has an example).
Eric
Previous Topic:Update fails "No repository found containing..."
Next Topic:Correct strategy for handling page changes in FormEditor
Current Time: Sun Nov 02 20:46:27 EST 2025
Powered by FUDForum. Page generated in 0.06862 seconds
