Home » Eclipse Projects » Eclipse Platform » key bindings to command and action
key bindings to command and action [message #334963] Thu, 12 March 2009 10:26 Go to next message
Is it possible to bind key sequence to one command in one view and to
amother command/action in another editor?
This is how I tried but no success:
application has scheme and context e.g.
myScheme
myContext
M1+R is bound to command - command1 and available in most of views and
works fine.
Now one editor has action say editorAction1 and I want to bind M1+R to
that action when user is working on that editor.
In plugin.xml
org.eclipse.ui.contexts
subContext - parent - myContext
org.eclipse.ui.commands
command - id set to ActionDefinitionId of editorAction1 say
editorAction1
org.eclipse.ui.bindings
commandId="editorAction1"
contextId="subContext"
schemeId="myScheme"
sequence="M1+R"
I put code to activate this context in focus gain of editor and
deactivate in focus lost i.e.
contextActivation = ((IContextService)
getSite().getService(IContextService.class))
.activateContext("subContext");
((IContextService)
getSite().getService(IContextService.class)).deactivateConte xt(contextActivation);
May be I am doing something wrong or missing something, any suggestions?
Thanks.
Re: key bindings to command and action [message #334981 is a reply to message #334963] Fri, 13 March 2009 11:25 Go to previous messageGo to next message
Any suggestions, how to achieve this?
Thanks.
PC wrote:
> myScheme
> myContext
> works fine.
> In plugin.xml
> editorAction1
> schemeId="myScheme"
> sequence="M1+R"
> ((IContextService)
> Thanks.
Re: key bindings to command and action [message #334988 is a reply to message #334963] Fri, 13 March 2009 12:58 Go to previous message
You're close.
PC wrote:
> In plugin.xml
> editorAction1
you need to define your command and then bind that to the keybinding in
your context (actionDefinitionIDs aren't really relevant) Is it that
you want a completely different command to be active in your editor (say
end-of-line) than active everywhere else (say copy-to-clipboard)?
> schemeId="myScheme"
> sequence="M1+R"
OK
This is fine. As long as you get your activation from your site, you
can do this once in createPartControl(*) and you don't need the
deactivateContext(*) anywhere (you get it for free).
What you have so far has created the keybinding, context, command, and
tied them all together.
Now you need to add a handler for your command. If you have an action
in your editor, you can do it directly using:
IHandlerService hs
= (IHandlerService)getSite().getService(IHandlerService.class) ;
hs.activateHandler("editorAction1",
new ActionHandler(yourEditorAction));
Use org.eclipse.jface.commands.ActionHandler
Later,
PW
Paul Webster
Previous Topic:question on visible when for command
Next Topic:Problems starting eclipse on moblin
Current Time: Mon Dec 01 12:33:10 EST 2025
Powered by FUDForum. Page generated in 0.03804 seconds
